Results 11 to 20 of 22
Thread: MAF & plug upgrade for MY K04
    Sep 2006
    You dont need a Maf
    Are you running 1 range colder plug which most people use on chipped cars
    MODS- TOO MANY
    Jan 2010
    Central Coast NSW
    No but I will get some, not sure which I used to run Iridium in my bikes but not sure on the cars?
    I thought I needed a 3in MAF but if not even better - cheers
    Sep 2006
    Do you have a 4bar FPR
    MODS- TOO MANY
    Jan 2010
    Central Coast NSW
    Yes I do have a 4bar FPR, also seat intake, Pipercross airfilter, BOV, de-cat turbo back 2.5in exhaust with rear collector box removed and std muffler.
    Sep 2006
    So you should be in business
    Why are you not happy with it?
    MODS- TOO MANY
    Feb 2007
    Brisvegas
    Pommie, I originally contacted ECS and they said there is a MAF for the 225hp Audi TT that has the 3" external and 2.75 internal dimensions which is what you need. Unfortunately they sent the wrong one which was the same as the polo. I never bothered returning it and passed it on to Jimmy. So try ECS again and see if they can measure one for you then ask for the part number and compare with the one I gave Jimmy to make sure it's different.
    Either way you are faced with the problem of the TIP being 2.75" external dimension and also the top of the stock air box. The other option is to use a custom 3" MAF housing with a silicone reducer pipe and a 3" pod set up like I just did seen here
    http://www.vwwatercooled.org.au/foru...-33911-22.html
    Feb 2007
    Brisvegas
    Quote Originally Posted by Pommie View Post
    If you're looking at the Custom Code stage III tune you need the MAF from what I understand.
    Sep 2006
    Jan 2009
    blankedy
    Right, sounds like you've got most of it sorted... Def CC, but sounds like you've already made that call...
    Going to be a nice toy once its done, i'd chuck in a sports cat to avoid potentially massive fines...
    Feb 2007
    Brisvegas
    Quote Originally Posted by vwthunder View Post
    And where were you 12 months ago Troy???
