Page 37 of 39 FirstFirst ... 273536373839 LastLast
Results 361 to 370 of 383
Thread: LZY13B build thread
  1. #361
    Dec 2012
    Well new dogbone in for about a week checked it on the weekend and looks to be fine kinda stuffed up tho and went too tight on one of the bolts and snapped it grrr so that was fun using a hammer and a hole punch turning it to get it out for the next hour haha
    Also think I might of found a problem looks like the whole subframe has moved forward about half a inch I can see the marks of where it was and where it is now. From what I’ve read our subframe bolts are stretch bolts and seeing as the mechanic dropped the subframe to do my control arm bushes I’m guessing that’s what’s stuffed it. Anyone else had this problem before? I’m dropping it off tomorrow morning to get looked at but I’m guessing this might be causing the noises and creaking noises and what damaged my other dogbone bushing other than this I’m just about all out of ideas
  2. #362
    nsw
    Unless he put scribe marks all over the subframes or you got a before and after wheel alignment, there is no way the subframes went back in in the same spot as they were initially in. They can also shift over time or with hard driving. Their misalignment is a handling/alignment issue but not one that would cause your dogbone to get chewed out. They need to be realigned and new properly torqued bolts fitted to make sure they stay put. Your average toe n go specialist wont know what you are on about so find someone good (pedders) and explain it to them prior to booking. To be able to shift them they'll have to slacken the steering rack bolts too as when two of these are tightened they bind the rack/crosmember and two subframes together.
    If you're serious you can get bolts sleeves which remove the freeplay between bolt and subframe hole. Someone like Seb from eurorevolution could probably help you with that.
    Don't know what the go is with the dogbone. Correct part#
  3. #363
    Dec 2012
    Well I’m tryint to sort out new bolts annoying that I can’t find anything online and I’ve been told I have to go to VW for them but once I get some I’m going to drop it off a pedders and get it done and get a suspension test done and hopefully fix up anything that could be making noise.
    On another note my boss wants to buy my polo he has driven it a few times and was shocked how quick it was when he gave it a hit haha he wants the car for his daughter to learn manual on also something he would enjoy driving around himself. He knows my mazda rx7 is for sale so hopefully that goes soon and was thinking of using that money for a upgrade. Kinda being looking at a mk6 golf gti I’ve always loved that shape but I guess I’ll see what happens
  4. #364
    nsw
    I think the bolts are a metric fine thread so not run of the mill bolts. You can get them from a fasteners supplier (I'd take the old ones as a sample) but you'd have to make sure they are 12.9 tensile which can be hard sometimes unless you get allen bolts heads. You may as well just get them through VW. They will be expensive but there's only 4 and they are critical bolts. Don't quote me but they are 90nm + a further 90 degrees or something like that so find out from VW on that and make sure Pedders know so that the subframes don't shift down the track.
  5. #365
    Dec 2012
    Had the car at the shop today having the suspension and the alignment checked and as they were checking the bolts they over tightened the dogbone mount bolt and snapped it
  6. #366
    I've had a mechanic do that before too - makes you wonder...
    Cheap, Fast, Reliable. Choose two.
  7. #367
    nsw
    better that than stripping it in the steer cross member. I was surprised to see that bolt only needs 25nm or something really low like that.
  8. #368
    Dec 2012
    Had it looked at by a local shop near my work today and he said the same thing that the whole subframe has to come out honestly I don’t trust these mechanics I’m gonna take a look myself this weekend cos I believe the bolt snapped above the mount so the mount should still come out and I should be able to make a little while in the middle and spin it out. According to the mechanic he couldn’t get the dogbone out but I’m gonna see for myself before I go down that road cos that won’t be cheap
  9. #369
    nsw
    so the mount is engaged in the steer crossmember and the bolt has sheered not at the bolt head but up inside the bushes insert? Fark that will be a challenge. You might be able to run a small drill bit up there and get into it with an easy out. If it did snap close to the top side thread you might be able to spread the opening of the crossmember enough that you can drop the dgbone down bit.
  10. #370
    Dec 2012
    Yes it’s snapped inside the insert but when I first looked at it I thought it had cleared the bushing so I’ll take a look this weekend and if I can still get the dogbone out it should be ok and that’s my plan to use a small dril and make a little hole and hopefully spin it out so it will be a interesting job
