Page 10 of 12 FirstFirst ... 89101112 LastLast
Results 91 to 100 of 119
Thread: Lower Front Lip - Possible Group Buy
  1. #91
    Aug 2007
    Perth WA
    done!
    i'll like gareth's method - pay someone else my front bumper is aftermarket anyway so there aren't any mounting points or slots like the standard bumper.
    thanks mate.
    '04 BMP MkIV R32 #144
    search getnew
  2. #92
    Point Cook, Vic
    well Troy and I had a crack at installing the splitter today. Heres the fruits of our labour.
    FOLLOW US ON FACEBOOK
  3. #93
    Jan 2009
    blankedy
    Looks good Tim!
    Was the effort much the same as the Mk4 writeup?
  4. #94
    Point Cook, Vic
    oops ive edited my post to fix the pic! I shouldnt type stuff on car forums whilst chatting to people on the phone
    The install was pretty simple so long as your game to take the front bumper off. You would probably do it without but I dont think it would be a wise move unless you have a hoist perhaps.
    On the polo the lip pretty much just gets screwed into the bottom of the current lip as the setup on the polo is a bit different to the mk4s undertray.
    We kept the posts in the centre of the lip quite long because we wanted to go for that gaping mouth kinda look.
    Ive taken a few more pics ill post them up in a sec to give you an idea of how it all went together.
  5. #95
    Sep 2006
    It was kind of fun, and the satisfaction you get when you have finished and stand back and see how good it looks
    MODS- TOO MANY
  6. #96
    Point Cook, Vic
    We trimmed down the posts just a little bit. You will have to get the angle right if you want it to sit flush. Id leave the final trimming till last.
    We then drilled a hole at the key points along the spoiler that we thought it would require securing. Then we carefully measured the centre of the bumper and the centre of the lip and secured the two front bolts. We chose to use some small bolts with a spring washer and a nut on the inner side. Nicer than using self tapping screws or something equally agricultural.
    Once the lip is tentatively secured by the two 1st bolts you can see how the curvature actually isnt too bad a match for the polo bumper. It is a tad too long though.
    Next we just worked our way along one side of the bumper carefully drilling small holes at the key points that will help the splitter to follow.
    It was pretty easy to lop the ends off with a dremel. Every serious DIYer needs to own one! You need to do it carefully though as you want to cut the plastic not melt it. We then finished the edges with fine sand paper.
    All finished!
  7. #97
    Point Cook, Vic
    I think the key thing to remember whilst doing it all is
    Measure twice, cut/drill once
  8. #98
    Jan 2008
    Cremorne, Melbourne
    that looks awesome mate. i didn't think the polo front would require a heat gun as it is not as square as the mk4's. looking forward to getting this on!
    2010 Reflex Silver MK6 Golf GTI
    Sunroof - MDI - Superchip - 19" VMR V710 - Kuhmo Ecsta SPT KU31 - VW Racing Panel Filter
  9. #99
    Nov 2008
    It'll be up on the hoist for me ... although if someone has instructions on how to get the bumper off, I might try it
  10. #100
    Point Cook, Vic
    Quote Originally Posted by DeanB View Post
    If you shoot me through an email to tim@dubaddiction.com.au i can dig up a PDF on how to remove the bumper if you like.
