Originally Posted by
h100vw
However, the point I wanted to get across is, that heat soak from the engine can elevate the water temp enough to trip in the fans. After the ignition is switched off. They don't run by magic.
It's certainly possible and every car is different
I'm not experiencing any heat soak with my Nissan Pulsar race car,
even after a 45 minute race around Wakefield Park
But it's NA - Turbo cars may be more susceptible to heat soak
Thanks for the details on the Polo cooling system,
it sounds fairly conventional and should be easy to work with (modify)
