Page 6 of 6 FirstFirst ... 456
Results 51 to 54 of 54
Thread: low temp thermostat
  1. #51
    Quote Originally Posted by sambb View Post
    Water temp sensing flange:
    42 Draft Designs Water Temp Adaptor - 1.8T - Polo 9n3 - Volkswagen - Shop By Car | Awesome GTI
    Oil temp/pressure adaptor:
    42 Draft Designs VW Oil Pressure Relocation Kit - Polo 9n3 - Volkswagen - Shop By Car | Awesome GTI
    I assume it goes into that port for a sender. Thats vacant on our car isn't it? - i'll have to have a squiz today
    The little plug on top of the filter mount could be used. Pretty sure that's where my Oil pressure gauge runs from.
    I honestly think you've spent excess time on this Sam.
    Fit an oil cooler and delete the heat exchanger. Don't go mad with the size of the oil radiator.
  2. #52
    nsw
    True, but I'm glad I managed to suss a few things out before I got it all back together.
  3. #53
    Dec 2012
    Sutherland Shire, Sydney
    It would be good to get those sensors installed
    Sounds like a plan
  4. #54
    nsw
    I've got a correction to make. A few posts ago I mentioned how VW had told me that the standard replacement thermostat is a 83/102 unit. Well today I was down there picking up a new radiator and PCV and asked them to check again on the spec and it is in fact an 87/102 degree. There was no optional 83 degree one in the system or any other possibility so what they told me previously was definitely a mistake and what VW sell does line up exactly with the aftermarket ones recommended for our car by dayco/tridon that are 190 farenheit opening.
