Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 54
Thread: low temp thermostat
  1. #31
    Sep 2006
    Tweed Heads
    Hoyhoy.
    I would get temps up to 108 when going hard on the track, then changed things to help with cooling, but still had high temps.
    Then woke up to switching the aircond on, on the cool down lap. When I pulled into the pits, she was cool & ready to switch off.
    Hooroo.
  2. #32
    Dec 2012
    Sutherland Shire, Sydney
    However, the point I wanted to get across is, that heat soak from the engine can elevate the water temp enough to trip in the fans. After the ignition is switched off. They don't run by magic.
    It's certainly possible and every car is different
    I'm not experiencing any heat soak with my Nissan Pulsar race car,
    even after a 45 minute race around Wakefield Park
    But it's NA - Turbo cars may be more susceptible to heat soak
    Thanks for the details on the Polo cooling system,
    it sounds fairly conventional and should be easy to work with (modify)
  3. #33
    nsw
    I'm stoked that the electric water pump is dedicated for the turbo, that is a cool little feature. Logically I suppose a lower temp thermostat won't help much after the car is shut down since the water pump isn't moving water around, and the electric one is most likely just for the turbo, and like Martin said there is only convection flow that may happen to some degree.
    A lower temp T stat would have to help for sustained track running though surely. I'd be curios what Seans temps are with that 70 degree thermostat. But that's not really my problem on short runs.
    Tridon do a standard OEM replacement and a 'high flow' version that allows 30 percent more flow once cracked, so i'll use that one. The only thing really left open to me is to finally re-gas the A/C so that I can make use of those fans on cool down too.
    Thanks for all the input fellas.
  4. #34
    Dec 2012
    Quote Originally Posted by sambb View Post
    Smart German engineering
    I doubt it
    People use these 70 degree thermostats on the street and don't have problems - not highly stressed
    But at the end of the day, there is a hot piston to bore clearance that is very important, especially in modern engines (running 5W30 oil)
    Running cooler may reduce that clearance and cause more friction and wear
    When I was a kid there was a nasty used car sales trick
    When they traded a car that was blowing blue smoke they would gut the thermostat
    This reduced piston to bore clearances and no smoke
    If the buyer noticed the temp gauge at 0 the salesman would let the car idle to show it would come up to temp (no air through the radiator)
    After buying the car the new owner is actually wearing out the engine running like this
    It's an extreme example but all the race cars I mess run at 90 degrees
    The racing guys are really hard core - if there was a good reason to run the engine at 70 they would
    Another point: Running at 70 degrees, your oil may be cooler and as such running at a lower viscosity, which could mean more wear
    I've seen those and am very doubtful about the 30% claim
    Just like a turbo inlet restrictor or an air flow meter, to flow 30% more would require more open area
    Those Tridon thermostats look much the same as stock
    Other points to consider:
    30% more flow is huge, the water pump will be what actually determines the flow rate
    Faster is not necessarily better - 30% more flow may not cool the engine and water may be travelling through the radiator too fast to be cooled down
  5. #35
    nsw
    I do see where you are coming from Martin I do. For sure you've convinced me that in my situation where its more of a hot shut off issue rather than a sustained running temp issue, I probably would see no benefit from changing to a lower temp thermostat. But for the track guys, our car has commuter rated cooling. Take Eddy's car (the closest thing here to a proper race car from what I can tell) and he said he's seen sustained 105 degrees on the track and that's with an oil cooler and tricky bonnet vents etc. Short of fitting an uprated radiator core, surely a cooler thermostat could help that situation by at minimum buying more time before temps get that high in a system that is otherwise being pushed to the limit. ie his fans would make no difference at full tilt, his thermostat would be wide open in either case, so its basically engine versus radiator - but if he starts from a slightly lower base it'd have to take a hell of a lot longer to get up to those peaks, maybe a whole session. Its possible isn't it?
    No I do agree with you regarding the 30 % flow thing. Its hard to know what effect it would have even if it was true. It had crossed my mind that if the flow was too fast that the coolant may not gather up enough heat on each pass. I've got no idea if OEM thermostats are built to restrict max flow by design. Maybe the water pumps have punchy flow from low rpms and the thermostat itself does in fact limit peak flow.
    Just for informations sake, tridon do standard flow and 'high' flow thermostats in 71, 75, 77, 79, 82 and 88 degrees increments. By searching under our car/engine, the stock standard flow is the TT1-190 (88 degree) and the high flow is TT2000 - 190. They both have a 54mm flange. But they then have lower temp versions of both of these:
    Thermostat | Tridon for the TT1 range of temps
    Thermostat | Tridon for the high flows.
  6. #36
    Dec 2012
    When you say the track guys, you mean hill climbs?
    At race tracks we have great airflow through the radiator
    I do agree with the commuter cooling design, and combined with hill climbs you're in a tricky situation
    The conventional approach to not being able to manage engine/water temperature is to increase the capacity of the cooling system
    Is there a larger radiator available for your car?
    It would be the single most effective change you can make
    Water injection into the inlet and over the radiator would be worth looking into
    (MCM did a crude water over the radiator setup and got positive benefits)
    Will a 70 degree thermostat solve the problem, starting from a lower base?
    It's possible it will have limited effect
    Without adequate airflow through the radiator (short hill climb),
    in a car that is struggling to control temperature
    does it mater what temperature the thermostat opens?
    I mean, once the temperature goes north, you're back to the original problem
    Maybe your second run will be cooler, but eventually the fundamental problem will occur
    The oil cooler will only cool oil - not the engine - and only with airflow
    By all means use the +30% thermostat - they will work fine
    My only point was ignore the +30% claim
    (I think I have one in my Pulsar race car! LOL )
  7. #37
    Dec 2012
    All I want is to smooth out any big temp differentials between the engine and radiator and the existing thermostat doing big temp dumps in and out of the engine.
    This won't be happening - the thermostat opens and closes slowly
  8. #38
    Dec 2012
    Oh - get a manual override control of both fans
    Let the engine warm up, turn on the override just before launching out the gate, leave them on for 10 minutes when you shut down
    That is likely to help you...
  9. #39
    Quote Originally Posted by Martin View Post
    The current oil cooling is assisted by the heat exchanger, that is part of the oil filter mount. The purpose being that the heat in the water warms the oil as the engine heats up from a cold start. Perfect logic for colder climates than Australia.
    When the oil goes over 90degrees the heat transfer is in the opposite direction. Heat transfers to the coolant.
    If an external oil cooler is fitted as Eddy has, including a thermostat, then much of the thermal load of cooling the oil with the coolant is removed. Consequently, the water temps will be way down. Far enough that it may be possible to run a smaller radiator.
    Especially true if the heat exchanger is deleted.
  10. #40
    nsw
    jeez I just sat down to a coffee after waking up after my nightshifts (which is why I've been a posting fiend of late) and that whole other variable of inter dependent oil temp is too much for my dusty brain to comprehend right away.
    So it sounds as though the exchanger system once everything is up to temp will work to hold the oil and water in equilibrium around 90 degrees.
    So if you were running an oil cooler (and especially if you didn't have the heat exchanger in place) you'd need the oil system to be thermostated or at least have a manual bypass of the oil cooler in place for when you're not on the track or its winter or your oil may not get up to temp?
    So if the spec oil temp is 90 degrees, how far outside of that will our oil temps climb just in street driven settings, and how out of hand do they get when the car is pushed hard (assuming the exchanger is still in place in a stock setup)???
