Results 21 to 30 of 31
Thread: Low speed front end knock after sitting for a short period
  1. #21
    Nov 2012
    WA
    Funny you should mention that, I've just received a set from eddy this week, yet to put them in. They are yet another arrow in my quiver.
    08 9n3 Polo GTI
    Mods: heaps
  2. #22
    Apr 2014
    Perth
    The morning boink is the subframe moving ? Sounds strange
  3. #23
    Nov 2012
    WA
    I don't think it is.
    When I had the superpro bushes fitted the shop mentioned they removed the subframe to do it. Not sure why though I did get both the front and rear LCA bushes done at the same time.
    The knock was there before this work and continued after, unchanged. If it was moving I would have thought the R + R would have sorted that out at least for a short period.
    Recently I've had a series of knocks appear, different to the morning knock, I believe I've got a couple of series of issues going on.
    08 9n3 Polo GTI
    Mods: heaps
  4. #24
    Apr 2014
    Perth
    Must be the hot weather here in Perth!
  5. #25
    Sep 2014
    I've had a knock or two today too, Perth definitely has not been favourable
  6. #26
    Jan 2015
    New Zealand
    Quote Originally Posted by rgvlee View Post
    I've yet to find it.
    After a reasonably thorough inspection I couldn't find anything amiss, everything seemed tight.
    I've lubed the drop links, sway bar chassis mounts etc and the knocks are still there.
    Since I posted this more knocks have appeared, mainly while braking particularly over bumps.
    I have much suspicions but that is all they are at the moment.
    I'm still looking into it. I haven't ruled out replacing the lot (suspension, sway bar, strut tops, drop links, rotors, pads), they are on my mods to do list anyway. I don't think it's one single cause now, I think at nearly 100k a few stock parts are getting a bit on.
    I isolated the knock on the drivers side in my car by removing that drop link. A few metres down the road and it was obvious that was the cause, even though I couldn't really discern any play in it.
  7. #27
    Nov 2012
    WA
    Yes I read your diagnosis, it's on my todo list
    08 9n3 Polo GTI
    Mods: heaps
  8. #28
    Jun 2011
    sydney
    Its not the ABS carrying out its self test procedure? I believe it does a test when you near 15 to 20kph
  9. #29
    Quote Originally Posted by buzuki View Post
    Never heard that one before. The ABS in my G60 Golf would trip off at the end of the street most days because I had a bad wheels sensors. The ABS looks for inputs from all 4 wheels.
    It doesn't actually apply the brakes or anything.
  10. #30
    Nov 2012
    WA
    I don't think so? This is a knock that started a few thou km after picking up the car.
    08 9n3 Polo GTI
    Mods: heaps
