Page 28 of 48 FirstFirst ... 18262728293038 ... LastLast
Results 271 to 280 of 476
Thread: Louis19's Build Thread
  1. #271
    nsw
    Car porn - love it! So external wastegate eh. It'll be tight where its exit pipe run against the firewall yeah. Are you making up a brace or something to support all that weight?
  2. #272
    Feb 2014
    Gold Coast, Queensland
    Quote Originally Posted by sambb View Post
    Thanks Sam. Yeah definitely planning on some sort of bracing, just to take the load of the turbo.
    Yep! It'll all be a snug fit in there, but I'll make it fit
    2006 GTI Polo - Big Turbo Build - Louis19's Build Thread
  3. #273
    Feb 2014
    Next few bits underway. Battery relocation nearly completed, just need to tidy up the wiring and finish the boxing fitment.
    Also had my box of IC piping arrive today so this weekend I'll be piecing as much of that together as I can.
  4. #274
    nsw
    Good stuff. Did you drill a gland through the firewall or find another way out.
  5. #275
    Feb 2014
    Used the same hole in the firewall that most use to route boost gauge hosing through. I just ground it out a little bit larger to allow room for the extra wiring.
  6. #276
    Apr 2014
    Perth
    Did you put a big fuse in at the battery?
  7. #277
    Feb 2014
    Yup I've got a large inline fuse to be installed
  8. #278
    Apr 2014
    Perth
    lesson from car audio days. Those fat cables burn good without a fuse
  9. #279
    Feb 2014
    Finished the battery relocation today and got a good start on the IC pipe work.
  10. #280
    nsw
    The IC is in a good spot with the hot side blowing in nice and low in all that clean airflow through the lower grille. Looks like you've cut away a fair bit of the fibreglass front apron above the radiator where the CAI feed usually is. Is that so you can get a proper size air feed through?
