Page 11 of 48 FirstFirst ... 91011121321 ... LastLast
Results 101 to 110 of 476
Thread: Louis19's Build Thread
  1. #101
    Feb 2014
    Gold Coast, Queensland
    Quote Originally Posted by Paazuzu View Post
    Cornered flatter but destroyed my front tyres too
    Good enough reason to jump on that 4 for 3 deal. Start saving those pennies Dan
    2006 GTI Polo - Big Turbo Build - Louis19's Build Thread
  2. #102
    Jan 2009
    A slight change in driving style can help with that. Enter corners straighter, so all braking in a straight line, tighter and later turn in to exit the corner straighter. It's a line I'm having to run more as I flogged my front left in one afternoon at the track, plus to help with power down on exit.
    It doesn't have to be a huge difference, a body width later on turn on to carousel and hungry will keep you straighter through the corner and on exit which takes some load off the tyre shoulder.
    Daily: 2010 VW Jetta Highline
  3. #103
    Jan 2014
    Clontarf, Queensland
    Quote Originally Posted by seangti View Post
    Very true Sean. Corner entry/exit became much more apparent with the new suspension setup - the tyres and brakes were under much more strain and it really showed me their limits. I'll send you a video link so you can give me some advice before 2016 time attack
    Mods >1
  4. #104
    Feb 2014
    Small update. After having my old exhaust setup starting to get on my nerves for daily driving needs, I decided to attempt to quieten it down. I removed the centre resonator which was 14" long and replaced it with one 24" long. That alone didn't make much of a difference so I decided to go a much larger rear muffler as well. So next I replaced the 12" x 5" muffler with a 14" x 8" DEA muffler, and what a huge difference that made. Its now a large chunk quieter then what it was and is much nicer for daily driving. Theres pretty much no drone now, highway driving isn't far off the noise a stock polo would produce and when you give it a bootful it has a much cleaner tone to it.
    A few guys have asked for a quick clip of what it sounds like so Ive added the link below.
    https://youtu.be/XeCK-eUSvdY
    Attached Thumbnails Attached Thumbnails Louis19's Build Thread-12279496_10152772088463078_1317319216_o-jpg   Louis19's Build Thread-12278272_10152772037178078_1874122857_n-jpg
    Louis19's Build Thread-12273073_10152772037253078_404316011_n-jpg
  5. #105
    Quote Originally Posted by louis19 View Post
    https://www.youtube.com/watch?v=oNpOhzk6kC0
    I found another one while while yours Louis
  6. #106
    Feb 2014
    Added my intake spacer today that I picked up off Gav yesterday. Install was pretty straight forward, just a bit time consuming with removing the fuel rail, injectors etc so I could have full access to the manifold itself.
    Initial impressions after installation - idle has definitely smoothed out a little bit more which I was hoping for, and it certainly feels as though it has a little bit more pull in the mid range, low and top end power feel much the same.
    Overall pretty happy, quite a good "cheap" mod I think. The true test will be at the next HL session to see the difference in intake temps after a few laps verses previously not having one installed.
    Attached Thumbnails Attached Thumbnails Louis19's Build Thread-12297826_10152781572908078_1358857488_o-jpg   Louis19's Build Thread-12318483_10152781653353078_895735269_o-jpg
    Louis19's Build Thread-12315035_10152781653443078_1565279841_o-jpg
  7. #107
    Oct 2013
    thats one thick ass spacer my one was only 5mm but yeh idle is alot smoother on mine to and alot more mid to high didnt you notice more punch down low i notice alot but my injector orings where bad and was leaking so i replaced them no more leaks and my spacer come with lil 5mm spacer washers for all the bolts and nuts take ur car for a drive and then touch the bolts u burn ur finger and them bolts push the heat in to the manifold
    My Beast: 06 Polo GTI~White~Milltec CBE~APR V2 Tune~SuperPro Bushes~WhiteLine FSB~Phenolic Spacer
    2nd Beast: 02 Audi S3~Stock
  8. #108
    Feb 2014
    Quote Originally Posted by HAR80N View Post
    Yeah I think certainly one of the thicker spacers going around. I didn't really notice a great deal of change with the low down power, only the mid range really but being that we have different turbo setups, the characteristics of the two will play a part in the way they perform anyways. The stock turbo was always torquier down low then my current one where as now mine has a lot more mid and top end pull then the stock turbo.
  9. #109
    Nov 2012
    WA
    Intake spacers the new black or something? Everyone doing them so it seems.
    08 9n3 Polo GTI
    Mods: heaps
  10. #110
    Feb 2014
    Quote Originally Posted by rgvlee View Post
    Certainly appears that way doesn't it! I had planned on getting one for a while, but jumped on the opportunity when a group buy was done last week.
