Page 47 of 48 FirstFirst ... 3745464748 LastLast
Results 461 to 470 of 476
Thread: Louis19's Build Thread
    Feb 2014
    Gold Coast, Queensland
    So last weekend I was out at QR again to test out a few things in the polo and monitor a few things. A few days before hand I went and saw Carlos and he gave me a hand to setup the link ECU for boost by gear as it’s going back on the dyno (hopefully this week) to set up the boost map for each gear so we can turn 1st and 2nd down but turn 3rd and 4th up and have the boost come on earlier. We will also be adding in a 4 Bar fuel reg to get another 100-150cc out of the injectors so it will be interesting to see what additional power can be added.
    On top of the boost by gear I’m making some physical changes, such as traction bars which I made yesterday and today. They will come back out tomorrow for some paint as they are steel. Only done a handful of pulls before heading home but the improvement is significant and very noticeable in the way the car acts under hard acceleration. I’ll also be looking to stiffen the rear spring rate, most likely in the form of rubber spring helpers/spacers that some drag racers use as you can just put them in on the day of the track day then remove them afterwards so you aren’t compromising on a stiff ride around town.
    Here’s the link to the last weekends session at QR. The V10 Audi R8 and Lambo owners was quite surprised to see they were shaking off the little ol’ polo
    YouTube
    2006 GTI Polo - Big Turbo Build - Louis19's Build Thread
    Feb 2014
    nsw
    Those rods, they'd help prevent castor change I suppose. Do they help with axle tramp too, is that the aim?
    Feb 2014
    Yup that’s correct Sam. The idea is it stops the lower arms moving around and unloading under power. Helps stop Axel/wheel tramp as a side effect.
    Feb 2014
    All painted and back on the car. Very happy with the end result these have made
    Nov 2012
    WA
    R&D it, profit
    08 9n3 Polo GTI
    Mods: heaps
    Feb 2014
    Quote Originally Posted by rgvlee View Post
    R&D it, profit
    May look into it in future, not sure many people would be interested in them to be honest.
    Apr 2014
    Perth
    Do you an LSD?
    Feb 2014
    Quote Originally Posted by Blue9N3 View Post
    Do you an LSD?
    Nope, standard open diff and gearbox just a pinion brace. Didn’t do LSD when doing the build as I was unsure if I would end up wanting 6 speed ratios but I’m happy with the 5 speed.
    Oct 2017
    Wodonga, Vic
    somewhere around 450Nm at around 5500RPM - Kinda mental
    Louis19's Build Thread-louis-torque-jpg
    I don't understand the attraction of this 'roll racing' thing, doesn't make a lot of sense - I reckon you should get yourself a helmet and start going around corners... but that's just me
