Page 42 of 48 FirstFirst ... 324041424344 ... LastLast
Results 411 to 420 of 476
Thread: Louis19's Build Thread
  1. #411
    Feb 2014
    Gold Coast, Queensland
    Quote Originally Posted by Sydneykid View Post
    Having run it for over 10 years I have found that issues with E85 are bit over stated/rated, but it is worth keeping mind that it is alcohol so it will "clean" the fuel system for the first few tanks. So any gunk anywhere will get dissolved and pumped. What I do is check the mesh filter on the pump and change the inline fuel filter regularly until it all looks clean. I cut the fuel filter open and check what's inside, when I see no gunk I then revert to normal service intervals.
    Gary
    Thanks for the heads up Garry that’s a great tip. I’ll buy a few fuel filters to have handy for the change over.
    I’m running a Walbro 460 in tank pump now so I can replace or clean the fuel pump “sock” easily if and when need be.
    2006 GTI Polo - Big Turbo Build - Louis19's Build Thread
  2. #412
    Feb 2014
    After what’s been a long 9-10 months, yesterday my polo went on the rollers for its tune. We ended up with 273fwkw (366whp) - so well north of 300kw/400bhp at the crank for those who work on those figures.
    At this power level the limiting factor was the 1000cc injectors on a 3Bar FPR. Originally when starting this project I hadn’t planned on running a full e85 so one day if this power level ever gets boring I can always swap out a couple bits for another big increase.
    Big thanks to John for a cracking tune and turning it around so quickly. Hitting the track this weekend for some rolling racing action to give it a shakedown. I’ll be sure to take some footage as well.
    Absolutely stoked to see all the hours that have gone into it pay off and have something to show for it.
  3. #413
    Feb 2014
    YouTube
    A quick vid that Dan (Pazuzzu) put together when he came and got a few snippets on the dyno day. Thanks for coming down mate!!
  4. #414
    nsw
    Awesome result man. jeez you're going to have to nurse the throttle to get any traction. Really interested to hear how the around town driveability/idle/progression/off boost etc with the LINK.
  5. #415
    nsw
    Louis how did you strap it down on the dyno. Did you go around the subframes and then diagonally backwards from there?
  6. #416
    Oct 2017
    Wodonga, Vic
    jeez that's a lot of grunt - it must be very entertaining to drive
    do you mind telling tell me your wheel size/offset and tyre size? I've hunted through your thread but can't find anything since the Enkei RPF1 and federal 595s. Doesn't look like you're still on the Enkeis, not sure about the tyres...
  7. #417
    Feb 2014
    Quote Originally Posted by sambb View Post
    Thanks Sam. Its certainly a wild handful now. Lights up 2nd like its on ice. Went to the track this morning for a shakedown and first time properly giving it a good squirt, it was lighting up the tyres in roll racing 3rd gear 140-160kph
    Driving around town its spot on, its actually driving the best it ever has. Throttle MAP is set to 1:1 so the pedal is very responsive instead of the lazy factory pedal feel. Idle needed some work but is now very smooth.
    I couldn't answer that one for you sorry mate I wasn't watching when he strapped it down.
    Quote Originally Posted by simon k View Post
    Cheers Simon. Ive moved away from the Enkei's to some AdvanRacing RG. 16x7.5" Wide, +30 offset with spacers. 225/50 Hankook RS3's.
  8. #418
    Oct 2017
    Wodonga, Vic
    Quote Originally Posted by louis19 View Post
    Driving around town its spot on, its actually driving the best it ever has. Throttle MAP is set to 1:1 so the pedal is very responsive instead of the lazy factory pedal fee. Idle needed some work but is now very smooth.
    that's awesome - can't hope for a better result than that -
    that's excellent, thank you - 225/50/16 has a diameter of 63.19cm, so I can run 205/55/16 with a diameter of 63.14 - problem solved!
  9. #419
    Feb 2018
    Good stuff. So glad it has turned out well for you and thanks for posting your current build it has been a good read and lets others know what works. You must be very stoked.. Keen to know a few good tuners/engineers etc around the Gold coast/Brisbane so please keep posting your recommendations. Enjoy!
  10. #420
    Oct 2017
    Wodonga, Vic
    apologies Louis - how thick are your spacers? IE +30 + ??mm
    Just looking at the total offset... 16x7.5 +30 has the same inner clearance as the stock 16x6.5 which is handy.
