Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Loud Knocking sound when going on bumps. Control Arm Bushes Worn out?
  1. #21
    Arrawarra
    Quote Originally Posted by seangti View Post
    I'd have thought up to a couple of hours. The labour will far exceed the price of the mounts. But it'll feel better than new once done.
    Yes you're probably right ... Mine was up on the hoist already having other work done so that would have cut some of the time component down...
  2. #22
    Mar 2015
    Perth, WA
    Thanks for all the help guys! Another question though.
    Is it common practice to replace the 6 bolts on the Balljoints (Part No: N10127707) and 2 bolts on the front wishbone bush (Part No: N10141801) with new ones when refitting the wishbone?
    Thanks
    Leon
  3. #23
    Quote Originally Posted by Amaze View Post
    Thanks
    Leon
    If you were being particular, you would do the front bolts. You should disconnect the ball joint from the hub, 18mm spanner, if the alignment was good before the bushes fell apart. It should be really close again, once you fit the new bushes.
    Disturbing the ball joints on the wishbone will need an alignment for sure.
