Page 16 of 18 FirstFirst ... 61415161718 LastLast
Results 151 to 160 of 178
Thread: Loose Turbo Bolts - growing problem
  1. #151
    Sep 2006
    Tweed Heads
    Hoyhoy.
    Since the last post, I have spoken to this mob, they don't make one on in our size for the Polo.
    The closest is 44m long with the right dia. & thread, we need at least 50mm long.
    But with a group of around 20, they might accomodate us.
    So who is interested.
    Hooroo.
  2. #152
    May 2010
    Durban, S.A
    Hi
    See this is a really old post, but i have just had this issue.... got lock washers, copper nuts and double nutted it... TIGHT! so far so good
  3. #153
    Feb 2007
    Brisvegas
    Although Jimmy's wire locking has stood the test of time without any stretching or loosening at all, it just took so much time to firstly get the turbo bolts drilled and then the locking process itself. This time we are going to try this
    K03/K04 Turbo Locking Flange - 034 MOTORSPORT
    Really cheap and it came with 3 new turbo bolts as well.
  4. #154
    Sep 2006
    Tweed Heads
    Hoyhoy.
    Anthony, the bolt locking tab will fit with your manifold, but not on a standard one because it has a raised section in the middle between the bolts.
    Also my advise would be not to use those bolts that came with the locking tab, they are only 8.8 tensile.
    The ones I had drilled were the same & they stretched & stuffed one of the hole threads in the turbo.
    Hooroo.
  5. #155
    Jan 2009
    blankedy
    Rise ye dead thread!
    So, as I'm tackling this on my own, some help please...
    Anyone know the aprox cost of the gasket? part number please?
    recomendations for the paste?
    Looks Like I'll have to pull out the heat shield, how tho? Does it pull up and out? I can see a collar on the piping behind the engine which could be used to hold up the drivers side of the shield, are there 2 bolts / holding it in place? Other than moving the 1 hard pipe bolted to the back of the block, will I need to remove anything else to get it out?
    If you remove all 3 bolts, does the turbo hotside then sag enough to get the gasket in blind?
    Lots of questions, would really appreciate any input you can offer. Seems to be about 10,000kms since this last came up, but the gasket wasn't replaced last time... Not sure if i've had a bad seal since or maybe the gasket survived. somehow...
  6. #156
    I could have sent you a gasket Ben.... Still can if you want to wait.
  7. #157
    Jan 2009
    blankedy
    Re: Loose Turbo Bolts - growing problem
    Thanks Gav,
    Hadn't thought about it until reading over all the details today.
    love one if you're sitting in a spare, cheers. I won't see it until Friday, so any old mail is probably fine.
  8. #158
    Thanks Gav,
    I'll post one tomorrow. I have a few spares and copper washers too if you ever need any in less than a week.
  9. #159
    Kuala Lumpur
    The locking flange is very interesting. No harm in giving it a try as it's cheap
  10. #160
    Jan 2009
    blankedy
    The locking flange does not take into account the ridge on our manifold between these bolts (need to be bent / longer arms).
    Can anyone comment on accessing the 3rd bolt and how to remove the heat shield / insert the spacer?
