Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
Thread: Loose subframe bolts
    It's been bugging me for a while now but every time I drive out of the driveway there's a knocking noise coming from the front right wheel well. At first I thought it was something loose suspension-wise, but I looked through the service history and there's a listing for the problem I'm describing:
    "Clicking noise when turning, found frame bolts slightly loose, retension all bolts."
    Good place to start right?
    I'm going to poke my head under this weekend and see if they're loose. Can someone advise where all the bolts are and what torque they should be tightened to?
    Also, any other ideas? Just in case it's not the frame bolts...
    Polo GTI MY2008
    Build Thread
    136.09kW and 305.28Nm torques, Dynapack Hub Dyno
    Feb 2008
    I'm thinking strut top bearings....
    Yeah that's the only other thing I could find.
    I forgot to add that I also feel a clunk when I accelerate, subtle but I can feel it through the accelerator pedal.
    Polo GTI MY2008
    Build Thread
    Feb 2007
    Brisvegas
    Check the passanger side drive shaft nut too mate.
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by VWindahouse View Post
    Any idea of the torque spec for this? I've been told the hub nuts are single use (stretch ).
    Resident grumpy old fart
    Jan 2009
    I get a similar knock as you've described. It occurs when going slow and some slight lock on the stirring, so rolling around second gear corners with bumps I get a knocking feel through the steering. It may happen more when turning left, but couldn't be certain. I have assumed this is rack rattle as changing suspension (by Jmac - so have all the confidence it was done correctly), strut top bearings were changed under warranty and rear lower control arm bushes are new too.
    It's happened since lowering the car (initially with springs only) and since had the above work done and still there, so gathered it's to do with geometry changes.
    May be similar... May be different. Might have a poke around under it as other provide input to your situation.
    Daily: 2010 VW Jetta Highline
    Oct 2010
    Melbourne, VIC
    Sounds suspiciously like my accelerator transition 'clunk' so I'm watching this thread with interest. Hopefully, mine will be resolved very shortly so I can add to what needs checking.
    Oct 2010
    I have this same issue. My car is booked in to Camden GTI tomorrow, and one of the tasks is to replace the front strut top bearings, so I'll ask them to check all the subframe bolts as well and see if that resolves the issue. Will let you know as soon as I have the car back.
    Jan 2009
    Quote Originally Posted by csimpson View Post
    If it's subframe bolts that loosen, wouldn't that mean the front end would be flopping around as that has (to my understanding) direct impact on your toe and camber settings?
    Found a figure of 81 ft lb and a 1/4 turn more for the subframe bolts, I'll give it a try this afternoon when the missus gets back from work.
    Loose subframe bolts seem to be a common problem. One of the fixes seems to be lock tabs and replacements subframe bolts from a Passat/Audi.
    If it's not the subframe bolts I'll replace the strut top bearings with the new suspension. OEM or aftermarket bearings?
    Polo GTI MY2008
    Build Thread
