Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Little torque steer concern.
    Sep 2006
    Brisvegas
    Quote Originally Posted by Eddy
    P.S. With APR this thing accelerates hard.
    I cant wait to drive one with it.
    For Sale 2006 VW Polo GTI
    Have a Look
    CUSTOM CODE
    Phase 2
    Nov 2006
    Remember, you only get torque steer once you get traction
    14.7 is pretty good. As a new owner (and also former Cooper S punter....the first time around ) my sense is that better damping control might give some t/s relief. But it's early days for me on this car, so I should keep my ears open and my mouth shut
    Apr 2006
    VW Race HQ - Sydney
    Play around with the tyre pressures and see if that makes any difference .
    I guess coilovers will help , but really you'll need to stiffen the chassis up and get an LSD to try and limit torque steer .
    I think I saw you at WSID when I was running some tests on the S3 . I think with my newfound power in the S3 I have gearing issues . Might be time for some NOS
    Sep 2006
    Australia?
    Quote Originally Posted by Bug_racer
    WOW crazy amounts of power coming from Seb. Doesn't that thing have enough power as it is? How much does it have at the moment Seb if you don't mind me asking?
    Sep 2006
    Tweed Heads
    [QUOTE=Bug_racer]Play around with the tyre pressures and see if that makes any difference .
    Hoyhoy.
    Just yesterday I swaped the wheels from front to rear & dropped the front pressures from 38lbs to 36lbs, seems better at this time. I changed the wheels around because I thought there might be uneven wear due to the burnouts when doing the 1/4's. Which I'm not doing again with this little girl.
    Hooroo.
    Seb u should no but isnt torque steer from drive shafts that are different lengths just bad design.
    I no a diff will help lol.
    Not exactly so, as the mini cooper s has equal length drive shafts(driver's side has a driveshaft extension to the C.V. joint) & even in standard form it has a degree of torque steer. Loads more with the JCW kit.
    I helped fit a LSD to one along with a smaller blower pulley & ECU upgrade amongst other little bit's & it had heaps of torque steer through the first three gears.
    Sep 2006
    Tweed Heads
    Hoyhoy.
    Like I say the torque steer is minimumal, & with the grunt the little girl is punching out, I think it is excusable. Thanks Boys.
    Hooroo.
Similar Threads
  1. Vans sold in NSW & VIC down on HP & Torque
    By jets in forum Transporter, Multivan, Caravelle, Kombi
    Last Post: 02-03-2007, 05:55 AM
  2. Torque
    By shaneth in forum Polo (9N & 9N3, 2002 - 2009)
    Last Post: 19-01-2007, 08:29 AM
  3. Front engine carrier to body bolt torque
    By aussieg60 in forum Mk2 Golf & Jetta
    Last Post: 14-10-2006, 09:57 AM
  4. Torque Ratings
    By golf3 in forum Tuning and Performance (inc ECU upgrades)
    Last Post: 29-07-2006, 06:49 AM
  5. Torque setting for bottom end
    By 82cab in forum Tuning and Performance (inc ECU upgrades)
    Last Post: 10-11-2005, 09:55 AM
