![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
gavs
Irrespective of if Anth goes with a diffuser at some point, the point I was making previously was that at the expense of less drag, the addition of high velocity, positive pressure into the negative pressure wake of the car would more than likely make the rear of the car unstable and render the wing useless. What I was suggesting was that he explore the addition of a flat floor on the car, with or without a basic diffuser to eliminate the drag issues cause by the rear bumper. I've seen many a Soarer or supra lose their expensive, votex rear bumpers on drag strips due to the drag from the bumper and I've also seen how just covering that area in can solve the issue cheaply, effectively an without the cutting of holes.
I still find this highly improbable (although everyone seems to have ignored my posts) due to the large separation between the wing and the bumper on the Polo. Look at the picture of the Civic with the massive diffuser and rear wing again - if a hatchback was liable to loose rear wing effectiveness due to repressurising of the wake, as you assert, then that car would show the effects. Anthony's car would be even less prone to be affected since his wing is mounted higher and more forward than the one on the Civic.
Soarers and Supras are completely different since the low angle of the rear window means that airflow can stay largely attached down to the boot lid which is not far above the bumper.
Horses for courses.
Resident grumpy old fart
