Looking good. Can't wait to hear it for real. Might have to go back to my exhaust man????? !![]()
3" exhaust system now on!! And so is the traction control light until third gearSo much POWER lol! Sound clips to come, but no drone at any rpm in any gear luckily and a very deep aggressive rumbly tone at idle and on the gas. When giving it the beans in 2nd it was a bit boomy with a bit of rasp as it climbed in rpm. But after the long commute home that's settling down a fair bit so expect that to continue over the next week. No boost spikes that I can see on the gauge but a definite increase in mid and high rev range power with an even louder turbo whistle than before. Happy days!
I asked the exhaust shop to get the entire system as far up into the tunnel as possible so it's out of the flow of air. Especially the rear muffler which I also got him to make a new hanger so I could delete the factory one for the same reason.
Shot showing the muffler now only hanging as low as the spare wheel well
All in all very happy with the outcome![]()
Pas d'escargot chez Walsh.
It's got to be this week though.
http://www.youtube.com/watch?v=_sjzBa3kVQM
Ant I can't actually imagine the Cfd thing would be that hard... What you are missing is the 3d model of the car... Solid works has a Cfd plugin which isn't hard to come by. The real challenge is developing the model to an accuracy to judge improvements. And of course being able to read the data. Alright so maybe its not easy, but certainly achievable.
Sent from my GT-I9505 using Tapatalk 4
No worries mateI wasn't really clear in what I was trying to say I guess, what I was saying is that the aerodynamic profile of the car is consistent, by no means is it efficient whatsoever
the drag-inducing vortices are of a consistent pattern (thank you Melbourne weather an the 9n polo on the freeway this morning!) so by adding a volume of high-pressure air into the consistent wake of the car will change the balance, that's what I was trying to say...
If you can extend the sills of the car downward as well as the front bumper, this will help quite a bit in keeping low pressure air under the car but you have to try and get a flat, level floor. Not like the factory underpanels which duck down under the subframe. It doesn't need to run the full length of the car and cover the whole lot in, just so long as its smooth and flat...
Haha I'm off to have me a Nitrous bath
Haha nothing good in life is easy!
Ok sweet, do you know by any chance how far off the ground the front splitter and side skirts generally should be? I'm restricted a little by a 80mm class restriction and I'm already pretty low. I must say you've got me thinking about the diffuser again.
Lower is obviously better, 80mm is pretty high but if you were to raise the suspension a bit and tweak your roll stiffness to counter the high COG (maybe also do some fun things with ballast...) you could make your bodywork lower to allow better under-car airflow.
Just remember that a diffuser in whatever shape or form you go with, doesn't need to be the full width of the car, obviously wider is better but I you take your current exhaust point and work with that as your outer extremity off the centerline, you can still tailor a fairly simple undertray to work with it but like I said, skirts are needed to keep the under-car airflow nice and cleansplitters also don't need to be the massive things you see on sport sedans and touring cars etc either, it just has to break the airflow.
Thanks mate, I'll do some measuring and take some shots to see what's possible. I really need some decent coilovers with stiffer springs I think, so I can raise the car a bit and not add any body roll. The FK's are as low as they will go without badly scrubbing out the inner tyre on the liners, and mated with both front and rear anti-roll bars on their hardest settings it's only enough to keep stability where I like it.
Plus I'm a bit worried about aftermarket skirts for this Polo. The way that the chassis rolls under the car there is no way of telling just how much they will drop as a portion of them will stay above the lowest point of the sill. Plus there are no suppliers in OZ so would be luck of the draw from an OS supplier. Yet another challenge![]()
Modelling is easy if you assume laminar flow and no separation of the boundary layer and not too hard if you assume a constant position (or section for a 3D model) where the laminar boundary layer separation (and thus the beginning of the wake) occurs.
In the real world, where you get varying separation and turbulent flow, ACCURATE modelling is almost impossible due to the effects if seemingly small disruptions in the body shape like windscreen wiper nozzles and the wipers and arms. The turbulence from these disruptions ALWAYS lead to early separation of the boundary layer, which is extremely difficult to model as the turbulence will start and increase as speed increases in unpredictable ways which then makes the drag coefficient change (usually for the worse). If you know EXACTLY what you are doing, then the situation can be improved by the addition of upstream vortex generators to create a turbulent boundary layer which can stay attached longer than a disrupted laminar one.
Then we need to consider large disruptions to the flow like wheel wells, the wheels themselves, side mirrors...
They still use wind tunnels for aircraft design, F1 etc for good reasons.
I still don't see a diffuser being effective on a Polo without removal of the wheel well. There is just not enough length available behind it for it to work. A good flat bottom tray and as much skirting as clearance allows to just to decrease drag is about the best you can do (and hence also increase the effectiveness of the front spoiler above the splitter). Conceivably, you could get some downforce by adding ducts from the base plate to the holes in the bumper as the low pressure in the wake could draw air from under the car - you'd have to test. Of course you could easily totally unbalance the car with masses of front downforce and not much at the rear.
That Civic pictured earlier has a massive rear wing mounted as far back as possible, again, for good reasons.
Resident grumpy old fart
