Originally Posted by
VWindahouse
Yeah heaps apparently Clay. A hatchback coupled with a rear torsion beam suspension set up is no friend to efficient aerodynamics.
I don't see the rear torsion beam as being an issue - in fact I think it is better than anything else for clearing the space at the rear. Rear wishbones or a multi-link rear end would place more components in the air path.
VWindahouse
Yes I don't really think a perfectly functional rear diffuser is an option with this car.
I think you could make it work if you were to remove the spare wheel well but then you would need to reroute the exhaust to the side directly (use a big resonator instead of a rear muffler?) to make it full width.
Resident grumpy old fart
