Page 100 of 111 FirstFirst ... 50909899100101102110 ... LastLast
Results 991 to 1,000 of 1101
Thread: Little Red Devil
  1. #991
    Feb 2007
    Brisvegas
    Lol only 52.5* mate. Pretty surprised at how well the Polo's perform in that department! But I guess the front top and bottom bumper grilles are pretty massive.
    The vents will really come into play when the massive open pod filter gets here and when the flat bottom splitter goes on. The passenger side vent is over and just behind where the pod is going, creating flow straight into and over it especially with the existing 3" duct feeding up from underneath. And will need more engine bay ventilation in general when the splitter goes on because it's going to cover the entire of the bottom of the engine bay
  2. #992
    Feb 2007
    Brisvegas
    So had fun today thinking up a rear diffuser. And also got around to shading my tail lights which is long overdue on account of hating the Polo's for like... forever.
    Well the verdict on the diffuser is maybe too much trouble than it's worth. Here's a pic of what your Polo looks like with no pants on
    As you can see it's near on impossible to get any sort of upward angle from the spare wheel well that's not too severe. So now thinking of just helping air flow. Any hatchback acts as a parachute at the rear therefore increasing drag the faster you go. I have a few ideas but started with the trusty hacksaw From this
    To this
    Investigating a couple of products at the moment which might help also and make things look more factory as well as B/Racecar
    Happy with the lights also
    Cheers.
  3. #993
    Feb 2007
    Brisvegas
    Quick update time starting with something not seen too often.
    Yes it's a dump pipe but not your conventional type This has a 4" expansion chamber that runs for 9" right after the 3.5" inlet, then down to 3" and flanged after the cat at 2.5" to meet the millteck catback.
    There is a bit of science behind the expansion chamber which was highlighted to me by a cluey fellow with an Audi TT on Vortex called Marcus_Aurelius.
    But first the big picture goal. So I've read that advancing timing doesn't actually increase cylinder pressures if done safely. This means that rods remain safe if the boost remains at requested levels with no spikes down low. However the adverse affects of too much timing advance is knock and EGT's rising to dangerous levels. So I want to see if I can hit the 200fwkw mark safely and to do that I need to make sure there is no back pressure affecting the little Ko3s turbine which creates high EGT's. Now our Polo's are lucky in that our DP design is fairly linear with no severe 90* angles the exhaust gases have to take directly after the turbo's hot side, so the only real thing that will increase back pressure is exhaust diameter. I have read everywhere that the magic diameter for 300bhp plus is 3". So my 2.5" system won't be helping and is increasing back pressure and EGT's.
    But there is also something else and this is where the science part I mentioned before come into it. Here is the post Max made explaining;
    Firstly, the expansion-chambered downpipe provided a huge improvement in spool-up time. It was there and very noticeable from the first WOT pull after the install. But at the track, it became very clear that this thing is a success and a must-have for anyone that takes turns in Motorsport conditions. It just made the car a rocket coming out of slow turns where spool time would be taxing any turbo car. The best way I can describe what it did in the spooling characteristics, is the car slingshots out of turns now, instead of steadily accelerating from them.
    Secondly, in terms of the physics behind it, there shouldn't be any loss of velocity but in fact improved flow out of the hotside. Normally, airflow coming out of the turbine wheel is in a spiral shape (the speed of the spinning wheel dictates the direction of the flow, which could be either following the blade rotation or spiralling in a counter rotation). This spiral effect is not ideal for flow and also reduces the gases velocity. By expanding the area right after the turbine, you effectively allow the otherwise spiraling exhaust flow to become turbulent. When the flow becomes turbulent (whirlpool-like), it allows the gases to move faster away from the choke point (turbine wheel and housing size). This is why you're able to achieve an improvement in flow and velocity by doing this. The closer to the exducer you can expand, the more effective the result will be, but obviously we all have to deal with space and packaging restrictions.
    I don't have the dyno data to quantify the results over the entire powerband, and didnt log/compare peak EGT differences yet. However, I can already say that the improvement in spool alone is well worth it for applications like mine and yours. Stay tuned and the raw data will be available in this thread as soon as the car is back and running again.
    The dynamics involved in providing expansion to the spirally gases:
    ... and a bit of explanation of the concept (better than mine ).
    Little Red Devil-max-2-jpg
    So now I can be assured that with the no immediate restriction caused by a 3" flange which would be half an inch smaller than the turbo hotside outlet, and the 4" expansion chamber going into the full 3" system with 100 cell cat and ceramic coating, I have given the turbo optimum efficiency with next to no back pressure or spiraling gases either spinning faster and or in the opposite direction to the turbine keeping EGT's at bay.
    So next up is to install the DP and hookup the air fuel gauge, then it's off to the dyno to play with the timing up to the point of knock to see what power we can see.
    Oh and also got the alloy TIP ceramic coated also
    Attached Thumbnails Attached Thumbnails Little Red Devil-max2_zpsade23854-jpg
  4. #994
    Sep 2006
    Tweed Heads
    Hoyhoy.
    Seems like your getting very serious Ant.
    Hooroo.
  5. #995
    Feb 2007
    Brisvegas
    Haha yes mate, giving this a red hot crack
  6. #996
    Dec 2006
    Hey Ant, Porsche club day at willowbank must be around again soon hint hint
    Quote Originally Posted by seangti View Post
    The price of the car rarely indicates driver ability/lap time.
  7. #997
    Mar 2013
    UK
    Little Red Devil
    Great work mate! Is there much clearance around the 4" expansion chamber to the bulkhead etc?
  8. #998
    Feb 2007
    Brisvegas
    Quote Originally Posted by jasn78 View Post
    Not a bad idea mate, you keen?
    Quote Originally Posted by sam_vw View Post
    Cheers Sam TBH I didn't get to see the trail fit but he tells me there's not much.
    Also enlisted the help of Gav and his grinder in reducing some rear end drag
    Also borrowing an idea from the Honda drag boys that should be here soon.
  9. #999
    Feb 2007
    Brisvegas
    And got a baffled sump from Forge that looks pretty nice
  10. #1000
    Feb 2007
    Brisvegas
    One step closer to some free flowing goodness
    And massive thanks to Greg from Carformance for this very nice 42DD stainless tip
    And here is the idea stolen from the Honda Civic drag boys
    Installed in the bumper to free up drag they have seen an increase of 4-5mph trap speed for the 1/4 mile But a total pita to install on the Polo as the Polo's bumper is curved and these thick alloy plates are not So got creative and bent them around a ceramic pot plant to get the right curves. Took ages. Then primed, positioned and drilled.
    And marked
    Then the fun part
    And after 3 hours or so, done!
    Sorry really crap pic, will grab a better one tomorrow.
