Page 92 of 111 FirstFirst ... 42829091929394102 ... LastLast
Results 911 to 920 of 1101
Thread: Little Red Devil
  1. #911
    Feb 2007
    Brisvegas
    Ive had it on soft for a long while, found the hard setting too jiggly at low speeds. just changed the bushes which has helped, it was bouncing a little before the bar loaded, so was messing around with traction. Bushes have helped. I do remember how well it cornered with the bar on hard, fun for street speeds.
    Sorry which bushes? Sway, control arm? Can't recommend the anti-lift bushes enough also!
    Quote Originally Posted by Jmac View Post
    Lol , its on mate, I pretty much finished clearing out today I can actually see the wee bugger now. If my mount idea works ill be full steam ahead, mind you only after I get the VR finished. Im moving soon so once all that dust settles itll be on. As you know I had no time to do anything to it really, I got the engine out with all good intention but business took over time.
    You know what its like investigating, doing sums, sourcing bits etc. Yours coming on nicely now. Shame not be part of it(now). Seems its in good hands though still.
    Keep up the good work
    Jmac
    Most eagerly awaited built on the forum mate so pull your finger out Scotty
  2. #912
    Jan 2009
    blankedy
    New swaybar bushes, the old ones were fatigued.
    Anti-lift bushes? As in the offset rear control arm ones that add caster?
    Gav, you had a tool for removing the old ones if I remember correctly, can you change them without having to pull the arms off the car?
  3. #913
    Feb 2007
    Brisvegas
    Yes Ben that's them, and yes Gav has the magic tool for the job too
    Ok so apparently my tachometer is a little out. By about 400rpm or so which I'm putting down to the fact that the tyres I'm running at the moment have a smaller rolling diameter than the factory size??
    So we completed another 3 runs in 3rd gear to the factory limiter at 7000rpm to see how the turbo behaves at the threshold. Here are the findings of the 3rd back to back run
    So air flow increased slightly bringing the peak power up a bit to 291bhp this time but things do drop off after 6600rpm.
    However an interesting 4th gear run (which was aborted a little early due to running out of runway ) the boost doesn't drop off at all up top
    Loving this turbo
  4. #914
    The arms have to come out but the alloy casting stays put on the car.
  5. #915
    Quote Originally Posted by VWindahouse View Post
    Loving this turbo
    It's a rocket, I am pretty chuffed with the results as well. Kev says he likes the logs and is happy that it doesn't need any updates to the map. Just one to delete the SAI code.
    I reckon we can get the extra hp if we dyno in Tasmania LOL
  6. #916
    Kuala Lumpur
    Loving this turbo
    I'm loving this mate! The boost comes in very nicely unlike mine right now
  7. #917
    Feb 2007
    Brisvegas
    Thanks mate Although sorry to hear your new turbo hasn't been clear sailing.
  8. #918
    Feb 2007
    Brisvegas
    Hi all, had a chat with Mark from Billet Turbo last week and found out what wheel sizes were in fact shoehorned into the reworked snail
    Compressor Wheel - Exducer 59mm, Inducer 45mm
    Turbine Wheel - Exducer 44.5mm, Inducer 50mm
    Not bad for a Ko3
    Also some pricing should be available soon through Gav (h100w) who will have these as part of a Custom Code Phase III package deal Can't recommend this combo enough!
    Plus huge news from CC head quarters in the UK regarding their game changing new tune technologies
    How do these sound;
    "No Hardware On The FLY, Push Button Map Switching Technology"
    Push To Pass
    Selectable RPM launch control
    Anti-lag Launch control
    Switch to any one of 10 calibrations on the move
    Stock , Valet , security lockout , E85 , Race Gas , Economy mode, 1/4 mile and much much more
    I'm excited, especially about the E85 switch tune! And to celebrate I thought I might join the 2.0L club so bought the first piece to the puzzle
    144/20's
    There's heaps I want to finish first before I start the necessary parts scrounge to complete the short block - pistons, crank etc.
    First off enlarging the diameter IC pipe sizing to 2.5" on the cold side now there's enough air flow to warrant it. Just waiting on the MAP flange to get here.
    Then it's onto finishing the aero stuff which will be very interesting indeed. Bits should start arriving this week. Plus hoping to get to a dyno soon.
    Cheers.
  9. #919
    Jan 2009
    blankedy
    No! Must... Not... Pursue... More... Power...
  10. #920
    Feb 2007
    Brisvegas
