Page 90 of 111 FirstFirst ... 40808889909192100 ... LastLast
Results 891 to 900 of 1101
Thread: Little Red Devil
  1. #891
    Sep 2006
    Interested in seeing what the little girl does
    Have you considered water meth, im sure water meth and a intake manifold and throttle body combo will make her even even more aggressive.
    It your turbo a one off, or will they make more if asked
    MODS- TOO MANY
  2. #892
    Quote Originally Posted by vwthunder View Post
    Is your turbo a one off, or will they make more if asked
    They'll do more but we haven't got a price yet. As the results are the important part to us at the moment.
  3. #893
    Feb 2007
    Brisvegas
    Don't think i'll go Meth but maybe some water and when CC finishes it's tune switching function I will be going down the E85 route for sure. For the IM and TB maybe down the track but a couple of other things need doing first
    Here is a snap of the catch can hooked up and the PCV blanked off and soon to be deleted all together when the new TIP gets happening
  4. #894
    Sep 2006
    How long do you think the rods will last or do you plan to wait till they break and change them
    MODS- TOO MANY
  5. #895
    Feb 2007
    Brisvegas
    Rods should be fine from the hundreds of hours I've spend researching both failures, hybrid and big turbo set ups on stock engines.
    There is a great thread on Vortex dedicated to rod destruction and unless you have a 30+psi boost spike below 3000rpm it really isn't likely at all. Gav and I finished logging yesterday so I might have time to do up some graphs today, but we saw it make exactly what it was requesting boost wise so no spiking at all which is a good thing.
    It all comes down to the turbo (ko4's are much worse than Ko3's for boost spiking and high EGT's do to the very restrictive hotside and exhaust manifold) and the tune (where boost and peak torque are made).
    Here is the best example I found
    Note the tuners comments;
    Yes engine internals stock. Stock rods do handle torque figures up to 400Nm as long as these 400Nm come after 3500rpm, this was tested on quite enough projects. 2860RS with <1.5bar boost is best buddy for stock 20vt engine, while customer gathers monies to buy upgraded rods.
    hopefully I can get some graphs done soon to show you the dynamics of this little beauty
  6. #896
    Feb 2007
    Brisvegas
    Ok so hope I got these right
    This graph is requested boost v's actual in psi
    V's my CC Stage II data for comparison
    And the new BHP figures graphed by converting the grams/sec readings at the MAF
    Peaking at 282bhp with just the base file and no timing adjustments
  7. #897
    Melbourne, VIC
    Re: Little Red Devil
    Wow thats awesome you must be pretty happy.
    So whats the converstion to hp from g/s
    Not from an iPhone.
    The daily
    White 2001 Mk4 GTI
    GIAC stage 1 - ECS stage 1 clutch & 14lbs Flywheel - 42Draft/Remus Exhaust - APR R1 dv - N75J - K&N
  8. #898
    Feb 2007
    Brisvegas
    Quote Originally Posted by theOctopus View Post
    Not from an iPhone.
    Very happy, thanks mate!!
    I found this for the conversion. It's what they use to determine HP from turbo compression maps;
    So I divided the g/per second by 7.55 (lbs per minute) and multiplied by 10hp. Hope that's right
  9. #899
    Aug 2012
    Sydney NSW
    Some great numbers there. Good to see.
    Looks as though the turbo is still pulling plenty of boost at 6000rpm whilst spooling at just over 2000rpm.
    Makes it a good match for the motor.
    Mate, with those numbers I still reckon rods would be cheap insurance!
  10. #900
    Quote Originally Posted by Redliner View Post
    YOLO.
    Tune is written with the knowledge the motor is standard. Anthony is comfortable with the thing as is, partly based on the fact it'll be high rpm running mostly and not booting hard from low revs.
    Rods is insurance but they are effectively a couple of grand by the time they are in there.
    It's been a calculated decision.
