Page 84 of 111 FirstFirst ... 3474828384858694 ... LastLast
Results 831 to 840 of 1101
Thread: Little Red Devil
  1. #831
    Quote Originally Posted by vwthunder View Post
    Well done gavin
    And anthony lol, what is going to happen with a tune for it, oh and what injectors are you running
    The tune is pending Troy.
  2. #832
    Feb 2007
    Brisvegas
    Well done gavin
    Lol nice
    Injectors are new Genesis II 500cc from USRT in the US. Have high hopes for these actually after seeing some comparative dyno plots on stage 2 & 3 1.8t's. With just injector changes nothing else they recorded decent ATW power increases but as always could just be creative marketing.
  3. #833
    Aug 2012
    Sydney NSW
    Quote Originally Posted by VWindahouse View Post
    Good choice mate.
    Thats what I should have used. Can't wait to see the results of your combo.
  4. #834
    Feb 2007
    Brisvegas
    Thanks mate, I hope they're worth the extra coin. Do you think yours will be done soon?
  5. #835
    Jan 2009
    blankedy
    I keep going back to the photo of the turbo.
    Must...resist...
    Cool toys dude, jealous.
  6. #836
    Sep 2010
    Wheelers Hill
    how do you find the lightened crank pulley? lot of people been telling me to remove it
    Audi A3 1.8 T
    aiming for 200kw atw
    http://www.vwwatercooled.com.au/foru...-8t-71747.html
  7. #837
    Aug 2012
    Sydney NSW
    Off to Westside tomorrow to do the exhaust and charge pipes. Ceramic coating will add a couple of days.
    Then Seb just has to finish everything off. Late next week we should be starting it.
  8. #838
    Feb 2013
    United Kingdom
    Awesome updates. Looking forward to the videos and hearing you feedback.
    389.3 BHP Polo GTI
  9. #839
    Feb 2007
    Brisvegas
    Must...resist...
    Lol yes I don't need a crystal ball to see one in your future Ben
    Quote Originally Posted by Njay View Post
    Yeah the lads on Vortex aren't a fan. I can't find any solid evidence and there are heaps of people that have been running one for over 100,000kms. I did find this though;
    The R&D team at ECS tuning takes great pride in the design and quality of our products. We we carefully match all OEM critical dimensions such as belt groove offsets, timing marks, belt groove profile, hole diameters, while optimizing performance. Our pulleys are designed in-house utilizing the state of the art CMM, laser scanning, CAD and simulation techniques and are then made in the USA. All of our products are subject to meticulous in-house quality inspection with our Faro Edge CMM, test fitment, dyno testing, and road testing before they are release for sale to the public.
    With any pulley, the overall outer width of the pulley is not critical to pulley fitment. In this case, stacking the OEM and ECS pulley on a table is not a relevant comparison as the crank mounting flange is concave and cannot be referenced without careful measurement. The technician made a good effort to do a comparison to the stock pulley, but did not have the proper equipment to measure the belt groove offset.
    To ensure the quality of this product, we have carefully reviewed a pulley from the same production batch as the customer's pulley to the OEM pulley via laser scanning with our Faro edge arm. We have also compared our CAD model file to the OEM pulley (as a double check of our design) and CAD model file to current production sample (as a double check of the manufacturing quality). We have confirmed that our pulley meets factory specification for critical dimensions: belt groove profile, diameter, and offset.
    There is a possibility that there is a quality defect with the customer's pulley. As soon as we receive this pulley and carefully measure and compare to the stock pulley, we will be able to determine if there is a manufacturing defect, or if the cause for belt failure is due to something else (installation error, or a worn or damaged accessory or idler pulley, or accessory misalignment).
    Note that any pulley axis angle or offset misalignment greater than ¼ degree or 1.59mm per 12" of drive center distance (distance from shaft to shaft) will result in premature belt failure. Also be sure to inspect all accessories and tensioner for smooth, drag free operation and alignment. The link below may direct you toward possible solutions if you continue to have premature belt failure:
    404 Page
    We have received the customer's pulley and performed a careful CMM quality inspection to verify the pulley matches both our design and OEM pulley specifications. The offset of the returned pulley is within an acceptable tolerance compared to the OEM pulley. We have also carefully measured for any parallelity deviation between the crank mounting flange and belt groove profile to check for any damage that could have caused the customer's problem, and we found that our pulley belt groove profile on our used pulley still has a tighter parallelity measurement than the OEM pulley.
    The rubber deposits on the pulley indicates that the belt was slipping, possibly due to a worn tensioner or due to excessive drag from another component in the serpentine system. Even if the belt grooves were misaligned, we would not expect to see the amount of debris that is present on this pulley.
    Based on our analysis, we are confident that the returned pulley is fully functional and meets our design specification.
    Regards,
    ECS Tuning
    It was from someone who had two shredded belts in a row who had a ECS pulley.
    Quote Originally Posted by Redliner View Post
    Sweet what are you getting coated?
    Quote Originally Posted by 9n3 Turbo View Post
    Cheers mate, base tune just arrived so pumped at the moment. Been waiting 4 years for this, since the ebay turbo fail.
  10. #840
    Jun 2009
    I hope this is tuned and slightly road tested before Happy Laps next weekend!
