It must be the added porkiness of the A3 body and the 19" rims that's chewing out the rotors
Quite seriously and concentrating on Polos, Eddy found the standard 288mm rotors just fine for stopping power when doing 1:10's around Wakefield. He upgraded to get more cooling rather then increase in braking power.
Resident grumpy old fart
I'm starting to get worried about your internals
I had a half-arsed look/attempt at fitting the rear brace this afternoon... can't say I like the massive frigging square holes where the bolts go through Looks like it's going to foul my fuel tank as well.. Did you have any problems like this Ant?
Almost there
Any chance it will be in and tuned by 15 December?
