Page 58 of 111 FirstFirst ... 848565758596068108 ... LastLast
Results 571 to 580 of 1101
Thread: Little Red Devil
  1. #571
    Jan 2012
    Bentleigh East, Melbourne, Vic
    Quote Originally Posted by VWindahouse View Post
    Have you put your weapon
    I like...."your weapon"
  2. #572
    Sep 2010
    Wheelers Hill
    Have you put your weapon on the track yet??
    engine is with the machinist at the moment im hoping its a month away from completition
    Audi A3 1.8 T
    aiming for 200kw atw
    http://www.vwwatercooled.com.au/foru...-8t-71747.html
  3. #573
    Feb 2007
    Brisvegas
    Sorry I though you were done for some reason. Maybe it was another A3 in the Audi section. Anyway I feel your pain, the waiting game sucks!
  4. #574
    Sep 2010
    Wheelers Hill
    Re: Little Red Devil
    Tell me about it, it's been of the road for a year
    Sent from my HTC Desire HD A9191 using Tapatalk 2
    Audi A3 1.8 T
  5. #575
    Feb 2007
    Brisvegas
    Whiteline adjustable end links are up for grabs. They are a touch longer than the links that came with the FK coilovers and I have them bloody low now so no good to me.
    Whiteline adjustable sway bar end links Golf MK5, Polo 9n3, Skoda Fabia MK1 & 2
  6. #576
    Could you have the links shortened...you might be able to still use them.
    Skoda Fabia II RS, OZ Racing Superturismo GT, APR, VW Racing, HP Polo 6R F/R arb's, DSG Tune, EBC Yellows, Motul, KW V3
  7. #577
    Aug 2007
    Sam needs a set mate
    Jmac
    Alba European
  8. #578
    Feb 2007
    Brisvegas
    Quote Originally Posted by SchuMi2 View Post
    It's all good, thanks for the suggestion mate. I only have a slight knock at extreme full lock which I can live with.
    Quote Originally Posted by Jmac View Post
    Jmac
    Brilliant thanks Jimmy, sent him a text!
  9. #579
    Feb 2007
    Brisvegas
    Ok so suspension overhaul is underway!
    Firstly massive thanks to Gav for having a good old crack at my guards with this new guard rolling toy! The rears are near on perfect and where splayed a good 4-5 mm more than before. So now when you look straight down from over the guard you can't see any trace of the top of the fat Federals.
    Just a recap on the rear ride height as some of you may remember when I had the FK's installed they were very low with no daylight between the top of the tyre and the guard and I subsequently had some scrubbing. This was when the car was full weight with rear seats and spare intact. Then I removed those and rear popped up about an inch. So now the rear guards completely cover the tyre I can lower it again. It's not quite as low as the first time so I will get it down a little lower but no scrubbing so far with just me in the car having some twisty fun last night. Gav also trimmed the plastic inner guard which would be helping that also.
    Then to the fronts. When I first had them done the guy said it was his first Polo and asked if I wanted to go ahead as he couldn't guarantee a good result. Turns out he was right due to the 2 metal tabs that are part of the guard that hold the plastic inner in place. it gave a slightly rippled effect in the paint and was not a perfectly even arch. However you had to look for it to really notice. Over time and due to the heat of the sun and metal being thin and stretched, the ripple has gotten a little worse. So we are thinking of cutting those tabs off all together to get this a little more even. I told Gav to experiment with the fronts as I didn't mind if they got worse because of a car park ding on one side on the panel just above the top of the arch and the opposite guard has been keyed pretty bad so worse case I get two new quarter panes which are pretty cheap from the UK. Anyway Gav managed to get most of the ding out and flared both guards out another 3 mm or so and also trimmed the plastic inners. NO SCRUBBING EITHER
    So when investigating the knock at full lock I raised the fronts coilovers a little and found an large increase in understeer on the track that the Devil had never suffered from before so I glad it's lowered once again so should be sorted.
    Now to the UR braces. The middle and rear under braces are on and I set the rear sway to hard for the first time. And wow is the rear end stiff as hell now as well as cornering completely flat. I did previously have some body roll with the front and rear sways set on medium but now with the rear on hard there is no roll at all!
    So gave it all really good test by accelerating very hard into and through a very sharp turn and the got some sliding oversteer from the rear end but it was easily corrected and controlled. I think the reason I didn't experience any snap oversteer is because I didn't let off the accelerator however I can see how you can easily get into trouble.
    So next is getting the Superpro anti-lift control arm poly bushes installed the UR front under brace, dropping the car all round a few more mm's and finishing with an experimental new alignment. Then it's off Lakeside to see what's up!
    And also the holes on the rear UR brace seem a little large for the bolts so will be talking to Luis.
    Cheers.
  10. #580
    Jun 2009
    Glad you are getting it all sorted.
    Any more news on when the turbo upgrade will happen?
