Page 56 of 111 FirstFirst ... 646545556575866106 ... LastLast
Results 551 to 560 of 1101
Thread: Little Red Devil
  1. #551
    Jun 2009
    Quote Originally Posted by VWindahouse View Post
    Hey mate, yep plenty but at the mercy of the turbo God at the moment. Story goes the final stage of getting the new bigger rear housing went pear shaped when the jig came loose in the CNC machine. And after that my one of a kind hybrid took a bit of a back seat due to some large paying customer orders and the boys from Billet going OS for business. Mark said to confirm with him again this Friday.
    So in the mean time I'm concentrating on the suspension set up and alignment. New bits arriving this week for that plus the three under braces from UR.
    Engine bay dress up coming along nicely too. And will try to get around to installing the new head unit as well.
    Trying very hard to keep up with you bro!
    So new turbo and tune by December 15?
  2. #552
    Feb 2007
    Brisvegas
    Mate I seriously hope so!! It's been more than 6 months in the making so better be faarrrking quick Can't wait to tear that TT drive a new one at happy laps. No one gets past the Devil....... except Tarmac of course lol.
  3. #553
    Haha here I was thinking I was keeping up with you! Nothing like a bit of mutual motivation I guess
    Haha that's funny; That's probably one of the motivations that made me consider the GT2860R recently... On the corners it might be a different story but I had absolutely no top end to keep up with the thing on the straight. Can't wait mate
    Polo GTI MY2008
    Build Thread
    136.09kW and 305.28Nm torques, Dynapack Hub Dyno
  4. #554
    Feb 2007
    Brisvegas
    Doesn't matter where you get the motivation from as long as it's motivating
    Anyway new bits!!
  5. #555
    Jan 2009
    blankedy
    Those drop links look tuff, nicer than the whiteline ones I had a while back that froze up with a little grit.
  6. #556
    Feb 2007
    Brisvegas
    Yeah pretty solid to hold put still relatively light weight!
  7. #557
    Feb 2007
    Brisvegas
    What's wrong with this picture?? Shiny new actuator from Forge but no turbo
    It's loaded with a yellow spring to match the upcoming boost levels!
    And the engine bling I mentioned earlier. Out with the old.....
    Trial fit the 3" MAF housing. Just trimmed the inside of the existing Forge TIP.
    Hopefully I can do the same with the turbo end as the turbo inlet has gone from a 45mm diameter to 50mm.
    Also took out the old head unit to make way for the new one. All wired up and working but having the same issue as Sam. Trimmed off the guides on the side but she still sits proud On a positive note I managed to feed the USB and Ipod cables through to under the steering column which give easy access and can't be seen from outside the car. You can just see the cables on the right of the photo
    Not sure yet if I like the position of the GPS antenna
    The rear also got a bit more Devilish
  8. #558
    Jan 2009
    So you're not going a huge, bird eating turbo with external wastegate, damn lol
    Daily: 2010 VW Jetta Highline
  9. #559
    Feb 2007
    Brisvegas
    lol want to see if I can bend a rod with the one coming so I have an excuse to stroke the little bugger and go a truck turbo sticking out of the bonnet
  10. #560
    Oct 2010
    Melbourne, VIC
    Go compound - then you can get some real boost happening
    Resident grumpy old fart
