Damn, ant noice but now you are banned from willowbank![]()
Awesome results Anthony! You need to update your signature to 147kw and counting! Impressive. It seems that Seat intercooler is the way to go!
06 Polo GTI - REVO Stage 2 = 140kw @ wheels.
06 Golf GTI - Bluefin Stage 1 blacked out with ED30 theme, leather, xenon, etc.
Yes mate, over the moon thanks! Yes thinking of getting a Wavetrac but no one can tell me what size ring gear to get. Our Polo's are either 113mm or 114mm ring gear. The Polo's came out with both![]()
Thanks mate, really appreciate the comments! Sorry will get your hold downs off to you tomorrow, ran out of time today.
Signature changed
Thanks mate, I still think your stage 3 missile would have me.
It's going to be a close one for sure mate!
Oh yeah! Thanks for popping around today Gav.
Thanks mate, really glad the change paid off. You've been quiet again, any news??
Friggin' pain isn't it? At least with the Golf MkIV, VW say that 2004 onward had the smaller ring gear yet they can't give a definite changeover for the Polo. I'm almost resigned to having my Polo pulled down before ordering a TBD which means it'd be out of action for more than a month!
Resident grumpy old fart
Yeah i know at peloquin they ask for the vin when ordering your diff, it might be worth the exercise with that, emailing the vin for a request for quote, mention you have a Polo. They probably use the same parts system as me seeing as independents dont get vin active Etka anymore after VW shut us down. i subscribe to Germany now ftw. Anyway where im heading is the 02R in the Polo has 02j bellhousing and 02r outer gear casing. Ik try not to muddle things up here as im thinking as i type. If they request the vin something must tell them what diam ring gear you have if it were a Golf, ive looked and cant see it but there isnt a magic program so after seeing so many they must ave something that tells them. So that being the case and if they do in fact use a similar program as i use then whats to stop them checking the Polo? its all vin active. I have a shredded peloquin that i could measure, there is only 3 gearbox codes for the 02R in the Gti , HWY, JDB and GVZ. Ill check what the casing is i have to see if it sheds light, not sure if it will but i would be trying the above with Peloquin, even if you are going Wavetrac. i reckon im going Wavetrac in my 6N, seems the go.
Cheers and sorry for the ramble
Jmac
Alba European
I just had a look on the Peloquin site and saw something that wasn't there before on the 113mm ring gear version of the 02J diff.
But it's all rather confusing when you read some of the preceding text which statesThis differential will be used in the 02S SEAT LEON and 02R Polo from this production date 01 10 03 this
date along with letters is found on top of trans. near shift cable connects to trans.
Plus will fit in the 2005 up 0A4 transaxle.
Some times
the Vin number won't work or trans. code number as VW has yet come up with a
way to tell the public which ring gear they have.
Would your comments also apply to my TDi, Jimmy?
Sorry for cluttering up your thread, VWindahouse![]()
No problem mate, this info will benefit all of us. Quick question on the date range from Peloquin - are they saying all Polo's with the O2R gearbox after 01 10 03 have a 113mm ring gear? Or is this an American site and the date is really 01 03 10![]()
I thought the Polo 9n3 GTI was only released in 2005 OS and 2006 here in Australia. So neither really make sense or am I missing something?
The Spams only swap the month and day round.
So instead of Ist October 2003 it could be 10th January 2003
I see it everyday at work with Americans servicing Qantas and V Australia at LAX.
They don't realise the rest of the world is different.......
PS apologies if you are American and do know the difference
