Page 31 of 111 FirstFirst ... 2129303132334181 ... LastLast
Results 301 to 310 of 1101
Thread: Little Red Devil
  1. #301
    May 2011
    Albury, NSW
    Im looking at changing from my KW's
    Troy why are you looking at changing the KW's? I was under the impression that FK's were great budget coilovers, but for ride quality and overall reliability you'd be better off going with something a little more like KW's - I was going to buy a set of Weitec's on the cheap from the UK, but you've got me questioning it now if you're thinking of downgrading! Maybe we'll all be on FK's soon.
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
  2. #302
    Sep 2006
    Quote Originally Posted by nightphotographer View Post
    Top of the range FK's use Koni adjustable dampeners, so i guess they must be good then lol
    Want something adjustable for the track, and the KW's, due to such big springs, guessing wont be suited to many Camber adj strut tops
    MODS- TOO MANY
  3. #303
    Apr 2011
    Are you just running V1s at the moment, Troy? I hate mine after the Teins in my old Subaru.. Not having any adjustability is pretty irritating.
    Adjustability/pillowball mounts would be nice...
    '16 Octavia RS Wagon
    Past - '07 Polo GTI
    '08 RenaultSport Clio 197
  4. #304
    Kuala Lumpur
    Quote Originally Posted by VWindahouse View Post
    insanekiwi - thanks man! Sure can on the Koni's too. I will PM you
    Thanks Jason, spot on mate.
    clict - thanks mate and good call on the gauges, it's quite a bit of work for sure.
    Sean - Mate totally different. Pretty sure the busted front strut and driveshaft mixed with some inexperience was my failing last time This time had a ball without crapping myself lol. Love the coilovers and can't say enough about changing my front sway bar to the medium setting. So much more traction off the mark as well as higher speed cornering on the track!! Seriously too much fun.
    There is also alot to be said about knowing the track too. All my lines, gear selections and braking seemed to come together straight away. Or should I say your lines
    Yeah would love to have a crack at some Turismo!
    Anyway some very bad shots to show the drop with the coilies. If it doesn't settle a little lower soon I will drop it some more
    Before
    After
    Also stock driveshaft bolt
    Audi bolt
    ---------- Post added at 08:38 PM ---------- Previous post was at 08:16 PM ----------
    Oh and got one of these too
    I noticed you're running on bigger 256mm brakes on the rear there. What are the parts needed? Can I just retain the stock rear hub and wheel bearing? Thanks
  5. #305
    Feb 2007
    Brisvegas
    Hey mate, yes spot on same hub and bearing you just lose the splash shield from memory. You just need the Audi TT rear calipers and the 256mm rotors. Oh and pads too.
  6. #306
    Kuala Lumpur
    Ok, will scout around for the rear brakes. Thanks
  7. #307
    Sep 2006
    Tweed Heads
    Hoyhoy.
    Boys ya can keep the dust shield just by cutting the outer edge off.
    You'll also need caliper carriers.
    I got this kit for the rear, no probs with fitting.
    Volkswagen Golf IV 1.8T > Braking > Big Brake OEM > ES#3936 OEM 337/20AE Rear Brake Kit - Version I - 33720AERBKSR
    Hooroo.
  8. #308
    Feb 2007
    Brisvegas
    Thanks Eddie! How did your light weight 312mm rotor's work out mate??
  9. #309
    Sep 2006
    Tweed Heads
    Hoyhoy.
    Had a problem with the carriers fouling, but all good now.
    I've done one track day with the new rotors, heat problem all gone & much more stoppy.
    Hooroo.
  10. #310
    Feb 2007
    Brisvegas
    New bits
    Thanks Jmac!!!
    Stealth look
