Results 1 to 10 of 1101
Thread: Little Red Devil
    Jun 2009
    Glad you like the noise pipe.
    There is a very thin line between not noisey nough and too noisey so it seems like you hit the sweet spot.
    Can't wait to hear it!
    Feb 2007
    Brisvegas
    Thanks Clay, and well said! It has got a little more noise going on now after my lengthy drive to work this morning but still in the comfort zone.
    Jun 2009
    Quote Originally Posted by VWindahouse View Post
    Funny, mine seemed to quieten down a bit as the exhaust ash coated the pipes and insulated the system
    Sep 2006
    How do you find the FK coilovers for daily driving.
    Im looking at changing from my KW's
    MODS- TOO MANY
    Feb 2007
    Brisvegas
    Great for daily driving, very comfortable over crap roads but I did have my Koni's set fairly hard in the end.
    I still think you should give a front sway on medium setting a go mate. From what you and kaanage mentioned in the other suspension thread about getting the power down coming out of high speed corners and under steer I truly believe it's the solution.
    And just to confirm I adjusted my front sway after the coilovers were put in so I have a fair comparison. I had no under steer with it set on soft but had the same traction issues pushing out of corners. So the setting change fixed it well. Never had so much fun in fwd car as i'm having now!
    Cheers.
    May 2011
    Albury, NSW
    Troy why are you looking at changing the KW's? I was under the impression that FK's were great budget coilovers, but for ride quality and overall reliability you'd be better off going with something a little more like KW's - I was going to buy a set of Weitec's on the cheap from the UK, but you've got me questioning it now if you're thinking of downgrading! Maybe we'll all be on FK's soon.
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
    Sep 2006
    Quote Originally Posted by nightphotographer View Post
    Top of the range FK's use Koni adjustable dampeners, so i guess they must be good then lol
    Want something adjustable for the track, and the KW's, due to such big springs, guessing wont be suited to many Camber adj strut tops
    MODS- TOO MANY
