So after the epic failure that was the AGU manifold project which wasted a large portion of the long weekend I decided to turn my attention to something else
Finally got the braided lines i've had waiting to make a dedut for the better part of last year put in for the next happy laps track session
Happy to say they did exactly what I was hoping for and gave a much firmer pedal feelReally happy with the whole set up now.
And then went to work on a sort of custom catch can set up.
Only good spot for it was to the right of the battery so decided to bolt it to the battery mount.
So then cut and bent the piece of 32x3mm strip of aluminium I happily found at Bunnings.
Drilled some holes for the little catch can bracket and fastened it with some SS marine screws. Then drilled a hole for the mounting bolt at the bottom.
Then fitted the catch can.
Then set about getting the hoses sorted. You can see the oil and crap that's being sent back into the TIP.
