Originally Posted by
VWindahouse
Update!
New boost gauge arrived. Think I mentioned earlier that the metal senders in the engine bay keep on frying because of the heat so I ditched them just for the boost gauge as it has a plastic sender that was mounted on the right hand side of the ECU cover and away from the nasty heat. This meant filling the space above the singe din head unit where the three old gauges were with a singe din VW pocket and moving to the air vent pod set up for the boost gauge
Only problem was at night the gauge was totally distracting because it reflected so brightly in the side mirror and was a little dangerous when going to change lanes as you couldn't see squat.
So went with a darker blue gauge that matches the taco and it's dimmable too. Looks really good in the flesh and on boost the analogue sweep screams around the outside and it also has the digital readout in the middle!
Hey Sorry old pictures but as i was looking through and drooling about all your mod,
i was quite intrigued with this gauge holder, really neat!
Does it still work as a normal airvent aswell??
Dont Want to boil in summer days=)
cheers matty
GIAC | FORGE | D2 | TURBOSMART | K&N | XFORCE |
