Page 5 of 111 FirstFirst ... 345671555105 ... LastLast
Results 41 to 50 of 1101
Thread: Little Red Devil
  1. #41
    Nov 2008
    Ok my bad, but there would be import duty on this, plus it does not include the CC Phase 3 software. Still over 200kw at the wheels.... maybe I'll start saving as I'm going over to the uk later this year.
  2. #42
    Feb 2007
    Brisvegas
    Quote Originally Posted by pogo_55 View Post
    Congrats on the upgrades Anthony looking forward to seeing a dyno graph from this when it is finished.
    I was looking at the JBS site and it appears that they do a "Plautos" to a K03. They put the innards from a K04 into the K03. I guess this is not the K04-001 innards but more like the ones Plautos used. This is the kit that gives 300bhp -
    http://www.jbsautodesigns.co.uk/prod...age-3-supplied
    Before everyone gets excited this kit costs 2628 pounds
    Is this the turbo you bought??
    Thanks a lot!
    I ended up just getting the straight forward K04-001 because I got a really good price for a new one on ebay. Please keep in mind I have been buying bits and pieces over time that I have had to budget for and usually looked to the USA for them as well because our dollar is stronger. Back up to 86c today infact.
    Also quick update, I will have a new type of TBD which will be in transit very soon And Jimmy has my new manifold and Turbo bolts ATM and is devising a permanent fix to the loosening problem!
  3. #43
    Jan 2009
    sunshine coast
    why would anyone spend that when they can just buy a "disco potato" for a lot less?......... oh and i read closer its actually a lil cheeper if you supply the turbo but thats still a huge mark up.
  4. #44
    Feb 2007
    Brisvegas
    Well it seems the Wavetrac TBD I was going to go with doesn't cater for the later model MK4 Golfs, so Peloquin it is. Should have ordered by the end of the month unfortunately, just waiting for the seller to get it in stock. So looks like I will get the turbo, manifold (which is getting HPC coated ATM)injectors, MAF, FPR and pump put in first then tune it all at the same time. Then get the TBD and clutch kit put in next to save some money.
  5. #45
    Jan 2009
    sunshine coast
    can i ask a really dumb question here and ask what "hpc" is?
  6. #46
    Feb 2007
    Brisvegas
    Yeah, here is some info taken from the website;
    A significant step up in its temperature handling capabilities is HiPerCoat™ Extreme coating. Specifically designed for applications such as turbochargers where substrate temperatures can exceed 1300 degrees Celsius, in black only the coatings help maintain exhaust gas temperatures, increase flow velocity, aid cylinder scavenging and assist in preventing damage to hoses, belts and wiring harnesses.
    Track testing has shown as much as a 30% reduction in underbonnet ambient temperatures and a 50% reduction in component skin temperature. HiPerCoat™ Extreme achieves this by creating a thermal barrier that retains heat, which in turbocharged applications assists to increase turbo boost and spool-up. Which is why today's leading CART, NASCAR, IMSA, and F-1 teams use HPC's HiPerCoat™ Extreme process.
  7. #47
    Aug 2009
    Belgium
    i've got my grill also from FK automotive.
    have to say, the red line is not on it so i used my original one and make it fit.
    and the grill itself does not fit 100% on my car.
    the underside of the grill does not fit well on the bumper.
    and i could not get the grill to fit unless i drilled away the round plastic thing in the middle that holds the stock VW logo.
    do you also have that problem?
  8. #48
    Quote Originally Posted by mikepologti View Post
    Its a really high quality thermal coating. It basically insulates the hot pipework, thus lowering engine bay temps. Hot gasses also flow faster too.
    One thing: It also causes so much heat to be retained in the metal that it leads to cracking exhausts and exhaust housings on your turbo, much the same way fibreglass wrap does.
    Not for street car use as far as i'm concerned, unless you consider exhaust parts a consumable item.
    Cheap, Fast, Reliable. Choose two.
  9. #49
    Jan 2009
    Quote Originally Posted by Stuwey View Post
    this has also been my observed experience with such things. Much like turbo beanies. There is some obvious validity in it, but there's also an added expense/risk associated to the benefits it brings.
    Daily: 2010 VW Jetta Highline
  10. #50
    Feb 2007
    Brisvegas
    There are different levels of coating available on the market depending on your application. In this case I am getting the lower end coating more suited to my application and I am only getting the exhaust manifold done which is a solid piece of manufacturing. This process is more the 10 years old and has been a tried and proven application my previous projects with no worries.
    PS I guess only time will tell with this absolutely insane Polo GTI from the UK
    http://www.tigerstyle.co.uk/phpBB3/v...8486&start=180
