awesome car buddy
where'd you get the badgeless grill?
Hey there guys, I have been wanting to introduce you to my little red pride and joy for ages and I finally found some time to post up. I have had my GTI for almost three years now and I can't get enough of it and the VAG culture I have found on the forum! Spending so much time on this forum and on the net researching has been a massive thorn in side of my relationship, but I have promised my girlfriend that my modding journey is almost at an end 'cough, cough'.
Just a couple shoutouts first all to Shane (shaneth) for helping me out with heaps of stuff on the Polo (group buys, parts, golden advise & for getting me in contact with Jimmy & Gavin). Gavin from Custom Code for a great product and for flying all round the country side to feed my need for speed. Greg from gslrallysport for the brake pads and rotors, great service and great prices. And last but certainly not least Jimmy Mac from Alba European. My little beast has probably spent 1/3 of its life at Jimmys getting the royal treatment. Mate your attention to detail, care, customer & quality of service are second to none!
A few pics
Latest list of mods 09/09/13;
Custom Code Stage III tune
3” cold air feed ducting
Modshack VTDA with custom cold air 3” ducting inlet with K&N pod filter
Custom alloy 3" MAF housing
Custom 3" turbo inlet pipe
Billet Turbo Ko3s Hybrid turbo with ceramic ball bearing conversion with Forge adjustable spring turbo actuator - yellow spring
Forge Motorsport 007P closed loop diverter valve with yellow spring rated 15-23psi
SEAT Sport intercooler - dual pass core
Custom pipe work - 2" hotside, 2.5" coldside to TB
ATP turbo hiflow exhaust manifold HPC coated
Custom stainless steel 3” dump pipe with 4" expansion chamber & Magnaflow 100 CEL catalytic converter
Custom 3" stainless steel catback exhaust with Magnaflow resonator & 6" round muffler with 42DD 4" outlet
Phenolic intake manifold gasket
ECS lightweight crank pulley
42 Draft Design Ultimate catch can with Morosso exhaust valve and PCV delete
SAI Pump, N249 & N112 delete
Wahler 71c thermostat
Genesis II 500cc injectors
Bosch 3 bar FPR
APR high performance in tank fuel pump
Verdict Motorsport O2J aluminium shift bracket bushings
42 Draft Design aluminium shift cable bushings
Deka lightweight ETX14 battery 12lbs 5.4kg
Braille aluminum battery mount
NKG BKR7EKT spark plugs
Superpro sports dog bone bush
Vibra-Technics Gearbox mount
Vibra-Technics Engine mount
Audi A3 custom drive shaft
Sachs 228mm duty clutch plate
Sachs clutch pressure plate
ECS 14lbs light weight flywheel
Wiechers steel front strut brace
Ultra Racing front lower control arm brace
Ultra Racing rear lower brace
Ultra Racing middle lower brace
Whiteline adjustable front sway bar 22mm set on hard
Whiteline adjustable rear sway bar 20mm set on hard
Whiteline rear shim kit +3mm toe in reduction
FK AK coilovers
K-MAC front camber & castor adjustable top mounts
Superpro anti-lift poly rear control arm bushes
Brembo 4 pot front brake calipers
Remsa Master HPT front brake pads
DBA 4000 312mm front slotted rotors
Audi TT rear brake calipers
Lucas/TRW rear brake pads
RDA 256x20mm ventilated rear slotted rotors
HEL braided brake lines
Enkei RPF1 17x8, 35ET, 15.5 lbs 7kg
Federal EVO 595 215/40R17
MK5 Golf alloy steering wheel inserts
SWG air vent pod
Prosport Evo electronic boost gauge
Prosport Evo electronic EGT gauge
Prosport Evo electronic air fuel gauge
ANS-420 head unit
Ford Focus RS bonnet vents
APR Performance GTC-200 48" SCCA Spec. carbon fiber rear wing
Rear bumper valance delete with JMF alloy bumper diffusers
Sharan antenna
Colour coded rear valance
Badgless upper honeycomb grille
Rear wiper delete
Fog lamp delete
Side skirt delete
Stripped out rear end
Total weight saving measures so far over 60kgs
OILS, LUBRICANTS & Fuel
Redline MTL gearbox oil
Penrite SAE 5W 30 engine oil
Penrite Racing Dot 4 brake fluid
BP Ultimate 98ron
awesome car buddy
APR V2 | APR Downpipe + custom catback | APR solid mount | FMIC | SEAT intake | BMC filter | FORGE 007DV | KW v1 | WHITELINE RSB
139Kw | 271.8Nm atw - At a new home
Here are some of the gauge senders and Jimmys stealth like install under the hood, the two pics on the left show the fuel pressure sender. The other two are the oil pressure and boost senders.
Great stuff. Any reason for using Redline MT90 rather than MTL (what's usually recommended, I think) in the gearbox?
Cheers mate, and I will just as soon as Jimmy can fit me in to get this stuff put in;
K04-001 Hybrid turbo
ATP turbo manifold
And on their way from the US as we speak are;
Bosch 315cc fuel injectors
ECS adjustable fuel pressure regulator 25-80+ PSI
Audi TT 225hp 3” MAF housing
APR high performance fuel pump
Then it's Custom Code Phase III time![]()
