Page 97 of 111 FirstFirst ... 47879596979899107 ... LastLast
Results 961 to 970 of 1101
Thread: Little Red Devil
  1. #961
    Feb 2007
    Brisvegas
    Quote Originally Posted by jasn78 View Post
    Lol helps to have mates with brains
    How much thicker does your mate recommend Jase?
  2. #962
    Sep 2006
    I wonder if you could hit the magic 200kw mark with rods, intake manifold etc.
    You said they can do bigger internals in the turbo
    MODS- TOO MANY
  3. #963
    Feb 2007
    Brisvegas
    Quote Originally Posted by vwthunder View Post
    Yeah pretty sure 200 won't be a problem. there are a few reasons why;
    This hybrid has the largest WG channel and wheels of any KoX hybrid out there plus the BB core can handle between 50-70 PSI as proven on all the pro drag cars that sport the same ceramic BB core design from Billet Turbo. So considering what power levels the current rodsafe 22psi tune (the same peak boost level as the CC Phase II tune) is achieving and remembering it's being starved of fuel at the moment because the last revised tune didn't cater for extra air flow from the IC pipework change, I think this little fella will really sing with a built engine on much higher boost. Plus I'm still on a 2.5" turboback exhaust which should really be 3" by now. But time will tell anyway, they're just my theories derived from some guys pushing similar hybrids on Vortex past 30psi and getting good reliable results.
    At this stage no variations on wheel sizes will be offered until this prototype can be fully tested which Gav will do when his is built in the near future
  4. #964
    Sep 2006
    It will be Year or two before i am ready for another upgrade anyway !!
    Be interested to see the EGT's
    MODS- TOO MANY
  5. #965
    Feb 2007
    Brisvegas
    Yeah thinking of stealing Redliners EGT probe idea. And a major advantage of using the ko3's hotside is the much larger 29mm WG channel from factory, so EGT's have been reported as being lower than than say for example a Ko4 at 24mm.
    Gav's will be ported even further too
  6. #966
    Quote Originally Posted by VWindahouse View Post
    Yeah, no measurements though. I did spend longer grinding it out, to make sure I got some in my eye
  7. #967
    Feb 2007
    Brisvegas
    Safety first Geez!
  8. #968
    Gav I hope you wear eye and ear protection whenever using power tools.... WPHS mate.
  9. #969
    Gav I assume your wearing approved eye and ear protection whenever your using your power tools, WPHS first and or first aid after!
  10. #970
    Feb 2007
    Brisvegas
    So while I get the parts together for the engine build I'm trying to sort out some basic aerodynamic components. Apart from a very lift happy rear end that the wing has thankfully sorted out, I now turn my attention to the front end. I feel the Polo has an inherent flaw in it's front end that has taken me a long time to find a solution but I think I finally have. The front end as a whole has a decent enough design to carry a low drag coefficient however when you look under the car it's easy to see why at high speed things have the potential to create substantial amounts of lift.
    Here are a couple of shots to illustrate what I mean
    The plastic bumper under tray is angled up from the back to the front therefore lifting the front end more the faster you go. And not to mention the completely vertical lip that runs the entire length of the under tray also
    Not a big deal at road speeds but a different story on the track. So my initial problem was leveling out that angle as just slapping a flat splitter under the front would just exaggerate the lift due to carrying the same upward angle. It's taken 6 months or so but I finally found something that will help. Meet part A
    It's not on properly yet and needs paint but as you can see it's created an air damn of sorts to push air up into the IC as well as giving me a completely flat underside to bolt up a flat CF splitter (part B) to create proper down force. I actually bought two of these if anyone's interested?
