Page 85 of 111 FirstFirst ... 3575838485868795 ... LastLast
Results 841 to 850 of 1101
Thread: Little Red Devil
  1. #841
    Feb 2007
    Brisvegas
    I was thinking more balls to the wall
  2. #842
    Aug 2012
    Sydney NSW
    Quote Originally Posted by VWindahouse View Post
    Sweet what are you getting coated?
    The downpipe and the heatsheild plus thinking about the outlet charge pipe from the outlet side to the throttle body.
  3. #843
    Sep 2010
    Wheelers Hill
    this is what the guys from asn linked me
    Audi A3 1.8 T
    aiming for 200kw atw
    http://www.vwwatercooled.com.au/foru...-8t-71747.html
  4. #844
    I'll give him a fiver for that cam belt if all the teeth are still on it!
    Just thinking that cam belt looks in good nick. I will bid up $5.50!
  6. #846
    Quote Originally Posted by Polo GTEye N9 View Post
    I don't want it that much Al all yours.
    A small progress report from this arvo.
    After a quick 10km yesterday once the whole thing was back together. I got a base tune from the lads in the UK.
    So I got in from work this arvo and got back into it again.
    First job was to swap out the 4 BAR FPR, that had been running in there for a while. Second, the 500cc injectors. The old ones came out easy, the new ones not so good on the way back in.
    Anthony had some fuel rail spacers from when he was going to use the 440 injectors. As luck would have it I found them in the parts box, on the second look!
    Ran out of luck straight away though, the spacers were too big.
    Removed spacer caps off the injectors. Injectors not long enough.......... Come on universe, deal me a better hand.
    Caps refitted, after a bit of measuring I decided that some 13mm nuts would fit under the rail nicely. They were just right. Then the chuffing standard bolts were too short and the spacer bolts bottomed out. FML
    So another pair of 13mm nuts, stainless and shiny I might add and we were all sorted!!
    Next job, 3 inch MAF housing. I had already test fitted it and opened up the mouth of the home made TIP. The Modshack CAI went on the other side with minimum fuss too.
    Last but not least, flashing the ECU. As the Devil has a tiny battery, I clipped on a bigger one with some jump leads, then loaded the tune. Started first flick of the key and settled into a nice steady idle.
    One fault in VCDS, I forgot to reconnect the inlet temp probe. DOH!
    Another couple of quick laps of the local estate and back in time for tea and a DSG flash on a diesel Jetta.
    Logging will happen tomorrow.
  7. #847
    Jan 2009
    I'm sure your day must have more hours in it than mine. That sounds like a days work.
    Daily: 2010 VW Jetta Highline
  8. #848
    Feb 2007
    Brisvegas
    Njay, you officially have my attention lol!!
    Sean, Gav has a habit of making a busy life look easy
    Sorry about the injectors Gav, I'll let the boys from USRT know.
  9. #849
    Jan 2009
    blankedy
    Progress!
    Nice box, needs a few more cable ties.
    I'm looking forward to hearing how some logging goes, seeing if the hardware and the ECU are cooperating.
  10. #850
    Feb 2007
    Brisvegas
    Ok went for a spin with just the base file loaded and well it's totally brilliant, thanks Gav
    Still comes on hard around 2000rpm like before but not quite as much as torque kick. Power delivery is so smooth now but mid and top range are crazy where the standard K03s dies in the ass, the hybrid just climbs in anger and doesn't run out of puff. I didn't even feel confident revving it over 5K on the street because it's pretty wild.
    Turbo whistle is awesome when it comes on, so very loud The entire package seems to be all working so well together and Gav's done a brilliant job with everything!
    More logging to come so the tune can be finalised then it's off to the dyno.
