Page 77 of 111 FirstFirst ... 2767757677787987 ... LastLast
Results 761 to 770 of 1101
Thread: Little Red Devil
  1. #761
    No worries and lucky the the rules are working in your favour.
  2. #762
    Feb 2007
    Brisvegas
    So at it again today with trusty old G.W. thanks a million mate
    Got a bit further with the strut top mounts but sadly not 100% there yet. The issue shouldn't effect those with OEM shape springs I'm guessing so those with KW's should be ok. We managed to get them in this time thanks to Kevin knocking up the right ID spring seats for the FK's. Here is a little assembly guide as requested
    Spring seat goes onto the spring
    Then the alloy top hat looking piece
    Then the top mount itself and the washer and finally the nut and the triangular washers if you don't have a strut brace
    Then it should look something like this from the top
    So the only issue I have is a loud creaking noise coming from the drivers side. Reason being the the FK springs run perpendicular (not bowed like the OEM springs) so the part of the spring seat that goes down into the spring is rubbing on the second coil. Kevin is knocking up some more seats for this which won't go as deep into the spring which should stop this. I believe all the group but mounts will now have this.
    The only other thing we did is trim the bumpstops a little because the ride height is actually reduced slightly which is great for those looking for more lows
    So just need the new seats and a good alignment and all done! We tested out the max negative camber setting for the drive home and it was a little too much without an alignment with some tramlining over 80kph but holy crap on that setting you can almost fit your fist between the top of the tyre and the guard Sorry don't have a photo of the extreme setting but here's one before it settled
    photo from rear to front
    Some ghetto aligning
    Then to finish off the Devil is now a few kg's lighter and is unofficially a 2 seater with more to come out in the future
  3. #763
    Feb 2007
    Brisvegas
    Ladies and gentlemen I am proud to introduce you to the worlds first ceramic ball bearing converted hybrid Ko3s - massive thanks to Mark at Billet Turbos...
    Check out the size of that inlet
    Wheel comparisons
  4. #764
    Little Red Devil
    ^ that looks great. How much extra power do you expect to be able to squeeze out of the modded turbo now? What size are the wheels compared to those on a K04?
  5. #765
    Feb 2007
    Brisvegas
    Not really sure sorry mate, being a prototype we won't really know until it's on and boosting And the wheel sizes are a secret at this stage and could possible change in the future although as you can see there is a decent increase.
  6. #766
    Jun 2009
    Super excited that it's all coming together.
    Is it likely the devil will have the new snail on and tuned in time for happy laps next month?
  7. #767
    Feb 2007
    Brisvegas
    I really hope so Clay! Very excited to see how it performs on the track.
  8. #768
    Jan 2009
    blankedy
    Epic few days!
    The turbo looks good, I'm hoping you get some good torque. So thats a stock hotside? Very cool.
    Glad to see the adjustable topmounts are coming good.
    Jealous mate, keep it up!
  9. #769
    Feb 2007
    Brisvegas
    Cheers Ben
    Yes some more torque across the mid to higher rev range would be nice but who knows what this little bad boy is going to do. At least I'm hoping for more power above 5000rpm where the stock ko3 tends to Rufi itself
  10. #770
    Feb 2007
    Brisvegas
    And yes sorry the hot side is stock at this stage but is the only place left that can be worked.
