Page 66 of 111 FirstFirst ... 1656646566676876 ... LastLast
Results 651 to 660 of 1101
Thread: Little Red Devil
  1. #651
    Feb 2007
    Brisvegas
    These should help with some extra late braking fun
    The calipers are actually from an Alfa Brera 2.2L I think Sam is also going to look at reverse engineering the custom carriers to fit the OEM size 288mm rotors. I'm not sure if it will be too relevant as the Brembos are all slightly different Matt from GSL tells me. So unless you get these exact calipers I'm not entirely sure they will fit Any thoughts?
    PS courier just arrived at home so man this day is going to drag on!
  2. #652
    Feb 2007
    Brisvegas
    Correction the Brembos are actually from an Alfa Spyder and GTV. Plus they are actually found on the rear of Ford FPV's BF onwards, go figure.
    Thanks to Matt for the fact finding and some pads and rotors on the way
  3. #653
    Jan 2012
    Bentleigh East, Melbourne, Vic
    Thought you already had larger calipers ????
    What are you currently running ?
    Polo 9n3 GTI
  4. #654
    Jun 2009
    Oh nice, so these are 2 pot calipers?
    The ones you have on now (TT?) are only single pot?
  5. #655
    Feb 2007
    Brisvegas
    Quote Originally Posted by clicht View Post
    On the rear only bud. Have the Audi TT 256mm upgrade. On the front's just had a slotted 288mm rotor with pads and braided lines. It's been a great upgrade as if balances out the terrible bias the Polo came with. But want something a little better now that things are getting more serious.
    Quote Originally Posted by team_v View Post
    As above Clay and I think they include both pistons on both sides so they're technically 4 pots.
  6. #656
    Feb 2007
    Brisvegas
    Here's a list of what I currently have;
    Stock Polo front calipers/carriers
    RDA 288x25mm ventilated front slotted rotors
    Audi TT rear brake calipers/carriers
    RDA 256x20mm ventilated rear slotted rotors
    HEL braided brake lines
    Lucas/TRW front & rear brake pads
    Penrite Sin 600 Dot 4 brake fluid
  7. #657
    Aug 2012
    Sydney NSW
    Interested to see how these work out for you with the stock size rotors.
    I've kept the stock size rotors on mine in case I want to put 15 inch rims with higher profile street/drag tyres to put it down the 1/4 mile.
    Not sure if my standard calipers are going to cope with the engine output.
    Would appreciate it if you keep us updated on how they perform.
  8. #658
    Feb 2007
    Brisvegas
    Sorry for the confusion - I'm actually going to a 312mm rotor with the Brembo's. We were just wondering if a set of carriers can be made to accommodate the stock 288mm rotors. As the original thread Sam started called BRAAAAKES IIRC, was talking about the Porsche calipers I don't think the custom carriers I have for these Brembo's will help as they're different.
    So you're focusing on drags mainly? (Hear that Jason, better get cracking on some more power I have a feeling the 13 second barrier is about to be history!!)
    I'm not sure if the stock calipers will fit under 15's so will be interesting to see. However any Brembo or Porsche calipers are bigger than stock so I think you may be out of luck with 15's. I know Wilwood make a nice set for the MK4 Golf that seem to be a little smaller than the others that might help.
    Can't wait to see your Polo finished!
  9. #659
    Aug 2012
    Sydney NSW
    Quote Originally Posted by VWindahouse View Post
    Mate, like all our Polo's, I don't think they're ever finished. Though it should be back on the road in couple of weeks.
    Really is more a tough street build rather than a drag car. May do some circuit work as well.
    Lots of good info on brakes.
    Keep us updated. Pics when they're done.
  10. #660
    Feb 2007
    Brisvegas
    So true! It's going to be a loooong two weeks
    Ok tonight I am officially thanking God! My guess work with the TDI third brake light seems to be a winner.
    But first this little beauty arrived
    Should keep the rear end nice and planted
    So back to the rear hatch. First pulled out the trim to reveal three bolts that hold the brake light in
    Then used the old trusty hair dryer on one of the ends of the GTI spoiler then before you know it it popped off to reveal what I was praying for
    a cavity that matched the shape of the TDI brake light
    Turns out there are just two dollops of glue on either end. Not really sure how to go about getting it off actually.
    Then the brake light test fit and wallah!!!
    Even the wire plug fits and light actually works.
    So took a gamble also with the wing. The new time attack rules for Club Sprint say the rear spoiler can't be higher than the highest point of the horizontal roof line even for hatchbacks. So luckily the polo's roof line slopes away considerably from the highest point near the front to the tail gate at the rear. About 5" or so. This leaves room for a low profile spoiler only and it took me forever to find one and even then it's a hybrid. The size of the mounting feet the width of the entire wing, the height of the wing and width of the pedestals all had to be accounted for. And lucking for me it all seems to be spot on so far. Starting with the mounting feet actually fitting on the tailgate!
