Page 35 of 111 FirstFirst ... 2533343536374585 ... LastLast
Results 341 to 350 of 1101
Thread: Little Red Devil
  1. #341
    Feb 2007
    Brisvegas
    My internet was down all bloody day sorry mate. Thanks Gav, very happy with the tune and results. Not too many cars out there that can boast a 45kw at the wheels increase from stock without a turbo upgrade.
  2. #342
    Eltham, Victoria
    Hey Anth,
    short of me trawling through every page of this thread (again, i'm sure i've done it before at work haha), I was wondering whether you could give a quick list of your "power" mods that got you to such an impressive number?
    I'd like to know how I can gain those extra 18 odd killer wasps
  4. #344
    Custom-Code is one thing See if Unitronics, custom setting utility will connect to your ECU then bump the timing up. It's a free download.
    You need a VCDS cable to make changes and log the timing pull.
  5. #345
    Feb 2007
    Brisvegas
    Quote Originally Posted by Bflat View Post
    Hey Anth,
    Ha ha glad I'm not the only one trawing through build threads at work! As Gav said mate, a lot to do with the tune but for me these other mods helped big time;
    ATP manifold which was HPC coated, 14lbs lightweight flywheel, Forge DV with yellow spring, colder plugs and thermostat and a phenolic spacer. Check out the first page of the thread for the updated list.
  6. #346
    Jan 2012
    Bentleigh East, Melbourne, Vic
    Brilliant
  7. #347
    Sep 2006
    Wow
    Thats 0.7 kw more than i made on the Dyno a year ago. I think Lauras was very similar, maybe 1kw more.
    MODS- TOO MANY
  8. #348
    Jun 2009
    Will be interesting to see what difference the Seat intercooler makes.
    Any reason why you chose the billet turbo route over the frankentrubo for future upgrades?
  9. #349
    Feb 2007
    Brisvegas
    Yeah, can't wait Clay! The main reason for going with Billet is the ballbearing component. It will have the usual hybrid parts Frankenturbo will have such as bigger compressor and turbine wheels and rear custom housing but will have Garrett GT28 characterisitics. This is taken from their site
    Billet Turbochargers are an elite true high performance turbocharger built from the highest quality parts and materials. They are lighter, spool faster and can handle higher thrust loads than have ever been achieved in any production turbocharger. Billet Turbo's was the first to utilise a full complement silicon nitride (ceramic) ball bearing system and is still the worlds most advanced turbo ball bearing system.
    Billet Turbo’s are available for small engines all the way up to the professional drag racer. Billet Turbochargers produce twin ball bearing turbo’s capable of flowing 2400hp per turbo making Billet Turbochargers the manufacture of the highest flowing twin ball bearing turbo’s in the world.
    Conventional ball bearing turbos use steel ball bearings, Phenolic (plastic) bearing cages and GMR turbines. Some brands are still using a single brass caged ceramic ball bearing and journal/bush oil bearing system.
    Billet Turbochargers takes the ball bearing turbo to a whole new level.
    Billet Turbochargers use perfectly matched aerospace grade twin full complement silicon nitride ball bearing systems and the latest technology compressor wheels and Inconel turbines. Inconel is the most durable material used in conventional production turbochargers.
    The perfectly matched aerospace grade twin full complement silicon nitride ball bearing system developed by Billet Turbocharger disregards the need for a bearing cage altogether. With out the need for a bearing cage the Billet Turbochargers ball bearing system has considerably less drag than conventional ball bearing turbo’s.
    The Billet Turbochargers silicon nitride balls are 58% lighter, 121% harder, than steel ball bearings, have a truer shape and they can withstand higher speeds, more heat and higher thrust loads. With lighter, truer shaped aerospace grade ball bearings and no bearing cage, then used in conjunction with the latest compressor wheels and Inconel turbines. Billet Turbochargers make more power, spin up faster and can with stand more punishment by design.
    The Billet centre cartridge and back plates are a unique advanced light weight, hard anodized precision CNC machined aeronautic grade billet aluminium piece. As well as being functional in strength, heat dissipation and weight saving. They look amazing. The quality of finish and attention to detail is first class. The Billet Turbochargers come in a standard colour range of anodized Red, Blue and Purple.
    Billet Turbochargers is leading the way of all high performance ball bearing turbo’s setting new benchmarks in performance, durability and Quality not seen in any other turbo
    Billet Turbochargers use the most technologically advanced turbo ball bearing system in the world
    • Perfectly matched aerospace grad full complement twin silicon nitride ball bearing system
    • Precision CNC machined aeronautic grade billet aluminium centre cartridge.
    • Latest technology Inconel turbines
    • Latest technology compressor wheels
    • Handle higher shaft speeds and thrust loads
    • Physically lighter
    • Spool faster
    • First class finish and look great
    • More durable
    Frequently Asked Question:
    Is the Billet Turbochargers ball bearing system just the same as other ball bearing turbo's ?
    Short Answer:
    NO!
    The Billet Turbochargers ball bearing system is NOT a copy of any other ball bearing turbo. The Billet Turbochargers ball bearing system is an original design developed by Billet Turbochargers. The basic idea for the advanced ball bearing system came from the aerospace sister company Talon AeroSpace. At Talon AeroSpace they develop and manufacture small gas turbine jet engines for defense force uses. The same principles as used in Talon AeroSpace ball bearing jet engines have been carried over to the Billet Turbochargers system. Gas Turbine jet engines have much higher shaft speeds, extreme heat and thrust loads than any turbocharger. These facts led to the unique high performing and robust design of the Billet Turbochargers ball bearing turbochargers.
  10. #350
    Jun 2009
    Okay, sounds like a worthy upgrade path.
    Definitley no way i am going to be able to keep up with you after that one goes in with a corresponding tune.
