Page 24 of 111 FirstFirst ... 1422232425263474 ... LastLast
Results 231 to 240 of 1101
Thread: Little Red Devil
  1. #231
    Feb 2007
    Brisvegas
    Update!
    New boost gauge arrived. Think I mentioned earlier that the metal senders in the engine bay keep on frying because of the heat so I ditched them just for the boost gauge as it has a plastic sender that was mounted on the right hand side of the ECU cover and away from the nasty heat. This meant filling the space above the singe din head unit where the three old gauges were with a singe din VW pocket and moving to the air vent pod set up for the boost gauge
    Only problem was at night the gauge was totally distracting because it reflected so brightly in the side mirror and was a little dangerous when going to change lanes as you couldn't see squat.
    So went with a darker blue gauge that matches the taco and it's dimmable too. Looks really good in the flesh and on boost the analogue sweep screams around the outside and it also has the digital readout in the middle!
  2. #232
    Oct 2009
    Canberra ACT
    What brands are the boost gauge and holder?
    Where'd you get them from?
    I'm looking at doing this soon
    06 VW 9N3 Polo GTI - Reflex Silver Leather/OEM Colour coded S/guard/OEM Lower Honeycombe Grille/NSP Boost Gauge/APR Stage 1+,Dogbone & DP/K&N filter/Forge s/shift,DV008 & Strut brace/PD 160/Samco camo TIP/Whitline RSB/FK AK's/17 x 8 Oettiger RE's/Alpine Head Unit & Sony Amp. OEM+FTW
  3. #233
    Feb 2007
    Brisvegas
  4. #234
    Oct 2009
    Canberra ACT
    Cheers VWindahouse! how long did it take to get to you?
    I see the holder is from the UK, is the gauge itself local or overseas?
  5. #235
    Feb 2007
    Brisvegas
    No worries! They took about two weeks to arrive and I bought them both directly from those links. It's a great gauge, you'll love it.
  6. #236
    Does the gauge dim down to the same brightness as the speedo/tach instruments? Looks good, I'm after a similar setup that wont stand out too much.
    Polo GTI MY2008
    Build Thread
    136.09kW and 305.28Nm torques, Dynapack Hub Dyno
  7. #237
    Nov 2008
    Quote Originally Posted by spraycanmansam View Post
    Same here, I want it to be there and be easy to see, but not shining bright like you see in a lot of other cars - don't want a beacon there !
  8. #238
    Feb 2007
    Brisvegas
    The photo's are a little deceiving sorry guys. It's not quite as bright as it looks and can be dimmed down via a little turn knob on the back of the gauge also. The middle photo where I used the flash is more acurate than the others I took in a pitch black garage with no camera flash.
  9. #239
    Nov 2008
    Canberra
    These seem pretty impressive gauges. I think I'll get one (probably digital series) to replace my mechanical boost gauge.
    Any chance of an under bonnet photo to show how you mounted the sender, and where you tapped into for the electrical feed?
    Thanks in advance.
  10. #240
    Feb 2007
    Brisvegas
    Sorry this is the best photo I have
    The sender is screwed onto the ECU cover and the wiring feed through the fire wall.
