Looking tough,
Im assuming this should hit the qtr in the high 13's with a good start.
2.5" catback?
A couple of the brakes, the one on the right shows the ventilated TT size rear rotors
Looks good. Any plans for an lsd or diff thingy of some sort to handle all that power?
Looks great .... needs the lower mesh on the front thought !
Alba European
I got the rear callipers really cheap so went that upgrade first and found that I liked the new combo enough to keep the fronts the same size. Pedal feel is a bit firmer then stock and progressive so it doesn't give you any surprises under heavy twisting conditions. Where as from the research I have read some people aren't all together happy who have just upgraded the fronts only. In the future if I end up doing a lot of track stuff I will go the ECS 312mm 2 piece light weight rotor option with Boxter 4 pot callipers (all together lighter than stock keeping the unsprung weight thing in mind). But very happy for now. You're welcome to give them a crack anytime mate!
