Page 107 of 111 FirstFirst ... 75797105106107108109 ... LastLast
Results 1,061 to 1,070 of 1101
Thread: Little Red Devil
  1. #1061
    Jun 2009
    Quote Originally Posted by VWindahouse View Post
    Not at all mate, glad you enjoyed it And I really appreciate the driver tuition. Can't wait to properly try your preferred lines and tip in points.
    I thought we were faster than 1:08 but then again you had a 70 odd kilogram weight penalty to cart around
    1:08 is pretty good for the amount of traffic and limited speeds we were dealing with.
  2. #1062
    Jan 2009
    Quote Originally Posted by team_v View Post
    Must of been a different event mate, no idea what you're talking about
    Daily: 2010 VW Jetta Highline
  3. #1063
    Feb 2007
    Brisvegas
    Well it's with a very heavy heart my Fiance and I have decided to part with the Devil. This is due to a few of the reasons culminating in the decision, such as taking a new job that's only a 10 min walk from home, a pending oversea's wedding and the onset of ankle biters. It was a toss up between Nat's Polo 77TSI and the Devil but the 77TSI has next to no K's on it plus 4 doors so it was the logical choice to keep. I will get a big 4WD or something more family and dog friendly later down the track.
    Ok so the Devil won't be available for another 3 weeks but all test drive requests welcome to anyone interested. Plus any questions please call me (PM for mobile number). It's a car that needs to driven to be believed and is a pleasure to drive in all situations. My guess after the new full 3" exhaust system went in is it's putting out about 190fwkw however last dynoed at 174kW and 413Nm.
    It's currently done 97***k's and mechanically perfect. It's a real testament to Jimmy and Gavin. It was serviced by VW for the 3 year warranty period and never had an issue not even the gear box. Then Jimmy put his magic and meticulous mark on it there after. I think it's log book was perfect just past the major 100,000k timing belt service that Jimmy did around 60K from memory. Before that he serviced it every 7500k's or so with filter change every time and only and still has only ever had Penrite Enviro oil. Good review here
    http://www.animegame.com/cars/Oil%20Tests.pdf
    After the 60 or 70k mark Gavin has done all the oil changes never being longer than 9000k's in frequency but not recorded in the log book which I still have and the plugs were replaced every 15000k's. The car will have one more oil, filter and plug change before sold also. Plus has had the factory coil pack recall done. Only thing I will mention is there is a slight knock on the driver side front strut when you go over a bad patch of bitumen and on full lock to the right the tierod hits the swaybar but I think if you raised the front coilovers a bit this would go away.
    Only ever and I mean ever had BP 98 in her also. The front tyres have about 60% tread left and the rear honestly look brand new. I also have a brand new EVO tyre I will include in the sale.
    It's a 2006 model but wasn't registered until Feb 2007, and has cloth seats with paint protection and a good tint (sorry can't remember the brand).
    For a car 6 years old it is in good condition with some usual stone chips in the bonnet and a parking lot scratch along the driver side quarter panel that stops on the door. And the interior is pretty immaculate for it's age too. And here is the current mod list with everything included;
    Custom Code Stage III tune
    3” cold air feed ducting
    Modshack VTDA with custom cold air 3” ducting inlet with K&N pod filter
    Custom alloy 3" MAF housing
    Custom 3" turbo inlet pipe
    Billet Turbo Ko3s Hybrid turbo with ceramic ball bearing conversion with Forge adjustable spring turbo actuator - yellow spring
    Forge Motorsport 007P closed loop diverter valve with yellow spring rated 15-23psi
    SEAT Sport intercooler - dual pass core
    Custom pipe work - 2" hotside, 2.5" coldside to TB
    ATP turbo hiflow exhaust manifold HPC coated
    Custom stainless steel 3” dump pipe with 4" expansion chamber & Magnaflow 100 CEL catalytic converter
    Custom 3" stainless steel catback exhaust with Magnaflow resonator & 6" round muffler with 42DD 4" outlet
    Phenolic intake manifold gasket
    ECS lightweight crank pulley
    42 Draft Design Ultimate catch can with Morosso exhaust valve and PCV delete
    SAI Pump, N249 & N112 delete
    Wahler 71c thermostat
    Genesis II 500cc injectors
    Bosch 3 bar FPR
    APR high performance in tank fuel pump
    42 Draft Design aluminium shift cable bushings
    Deka lightweight ETX14 battery 12lbs 5.4kg
    Braille aluminum battery mount
    NKG BKR7EKT spark plugs
    Superpro sports dog bone bush
    Vibra-Technics Gearbox mount
    Vibra-Technics Engine mount
    Audi A3 custom drive shaft
    Sachs 228mm duty clutch plate
    Sachs clutch pressure plate
    ECS 14lbs light weight flywheel
    Wiechers steel front strut brace
    Ultra Racing front lower control arm brace
    Ultra Racing rear lower brace
    Ultra Racing middle lower brace
    Whiteline adjustable front sway bar 22mm set on hard
    Whiteline adjustable rear sway bar 20mm set on hard
    Whiteline rear shim kit +3mm toe in reduction
    FK AK coilovers
    K-MAC front camber & castor adjustable top mounts
    Superpro anti-lift poly rear control arm bushes
    Brembo 4 pot front brake calipers
    Remsa Master HPT front brake pads
    DBA 4000 312mm front slotted rotors
    Audi TT rear brake calipers
    Lucas/TRW rear brake pads
    RDA 256x20mm ventilated rear slotted rotors
    HEL braided brake lines
    Enkei RPF1 17x8, 35ET, 15.5 lbs 7kg
    Federal EVO 595 215/40R17
    MK5 Golf alloy steering wheel inserts
    SWG air vent pod
    Prosport Evo electronic boost gauge
    Prosport Evo electronic EGT gauge
    Prosport Evo electronic air fuel gauge
    ANS-420 touch screen double din head unit with GPS
    Ford Focus RS bonnet vents
    APR Performance GTC-200 48" SCCA Spec. carbon fiber rear wing
    Rear bumper valance delete with JMF alloy bumper diffusers
    Sharan antenna
    Colour coded rear valance
    Badgless upper honeycomb grille
    Asking $15,200
    Cheers,
    Ant.
  4. #1064
    Sep 2009
    brisbane
    Jan 2009
    blankedy
    Wow... Sad day dude...
    Best of luck for the future.
  6. #1066
    Nov 2007
    I feel your pain Ant, so sorry to hear. Mine is also moving to a new owner as of coming Sunday
    As you say, 4 doors and something newer is logical just doesn't go well with the heart .....
    When you are ready to buy again, come have a chat and look at something that will tick all your boxes above .... even stay in the VW fam ....
  7. #1067
    Aug 2012
    Sydney NSW
    It will be sad to see all your input go.
    Good luck with the sale.
    That's a great price. Hope it goes to a good home.
  8. #1068
    Anthony,
    I was only today reviewing you car list of mods of two years ago.... what a difference to present.
    Your asking price is so fair and should see you lose it fast!
    Sorry to see you doing this, but a man has to do what a man must do!
    I know I spent several years building my previous MY06 WRX with much sweat and tears. My wife was afraid of it and would not drive it! So sold!
    All the best mate, cheers Al
  9. #1069
    Feb 2013
    Eatons Hill, Queensland
    That must of been a hard one...it is an amazing car which has been looked after by an amazing owner.
  10. #1070
    Jul 2013
    Caulfield, VIC
    Damn! Seems cheap to! Get an Octy for the fam
    www.TheRapidWrench.Melbourne
    The convenient, professional and affordable mobile bicycle mechanic that comes to you!
    My RS build thread
