Page 104 of 111 FirstFirst ... 45494102103104105106 ... LastLast
Results 1,031 to 1,040 of 1101
Thread: Little Red Devil
  1. #1031
    Feb 2007
    Brisvegas
    3" exhaust system now on!! And so is the traction control light until third gear So much POWER lol! Sound clips to come, but no drone at any rpm in any gear luckily and a very deep aggressive rumbly tone at idle and on the gas. When giving it the beans in 2nd it was a bit boomy with a bit of rasp as it climbed in rpm. But after the long commute home that's settling down a fair bit so expect that to continue over the next week. No boost spikes that I can see on the gauge but a definite increase in mid and high rev range power with an even louder turbo whistle than before. Happy days!
    I asked the exhaust shop to get the entire system as far up into the tunnel as possible so it's out of the flow of air. Especially the rear muffler which I also got him to make a new hanger so I could delete the factory one for the same reason.
    Shot showing the muffler now only hanging as low as the spare wheel well
    All in all very happy with the outcome
  2. #1032
    Looking good. Can't wait to hear it for real. Might have to go back to my exhaust man????? !
  3. #1033
    Feb 2007
    Brisvegas
    Yes sir, I think you might Any word on Le Snail??
  4. #1034
    Quote Originally Posted by VWindahouse View Post
    Pas d'escargot chez Walsh.
    It's got to be this week though.
    http://www.youtube.com/watch?v=_sjzBa3kVQM
  5. #1035
    Nov 2012
    Ant I can't actually imagine the Cfd thing would be that hard... What you are missing is the 3d model of the car... Solid works has a Cfd plugin which isn't hard to come by. The real challenge is developing the model to an accuracy to judge improvements. And of course being able to read the data. Alright so maybe its not easy, but certainly achievable.
    Sent from my GT-I9505 using Tapatalk 4
  6. #1036
    Jun 2008
    Ringwood, Victoria
    Little Red Devil
    Thanks Gav, appreciate the input! Couple of things though and certainly not saying you're wrong here. Yes something like the Clio diffuser was my first intention. Minus the huge budget for part development and wind tunnel testing of course
    I look at cost v's benefit with all this as well as being within the category rules and the rules say wheel well stays and a custom diffsuer can't go past the rear bumper. Plus I can't have a flat under body panel between the front and rear axles which isn't such a big deal as the Polo has two plastic panels running that length of the body either side of the exhaust tunnel and the exhaust itself is up quite high and not in the flow of air.
    I also look at all the top hatchback time attack cars from all around the world to get ideas as they do spend massive coin on aero as there are basic principles when dealing with the very unique combo of FWD and hatchback chassis. Most of the fastest are sadly Civic's not Clios, Polo's or even Golf R's for that matter.
    Now the biggest issue with any hatchback is rear end lift and drag. Usually caused by the same inherent design issue which causes a parachute effect at the rear from the air travelling under the car which there is a lot as these hatchbacks also have a very high COG. My Polo still has a high COG and it can't go any lower. In reflection banging on the wing was just masking the real issue as the lift is not caused by the top of the car.
    So for your last comment can't say I agree. You are assuming the Polo's overall aero dynamics are well designed from factory. Well it's far from. Here are some wind tunnel testing of the MK5 Golf 3 door GTI (same chassis and shape as my car just a larger version)
    So at 200kph the rear experienced 37kgs of lift and only 2kgs at the front.
    And here are the other variants from VW that suffer the same massive lift in the rear end
    Golf R32
    36kgs of lift at the rear and 3 at the front
    Mk6 Golf GTI
    A little better at 33kgs at the rear and 5 at the front.
    So there is one thing all these very similarly shaped hatchbacks have in common and that a very short and squat rear that catches the underside air flow like a parachute as I said before. This also causes a high pressure build up right where there should be any at all. Just for comparisons sake the Audi RS3 has only 21kgs of rear end lift
    and the the best hatchback I can find is the Focus RS with only 4kgs lift at the rear
    So VW obviously didn't spend a heap of time in a wind tunnel when designing the shape of hatchbacks in question.
    My point is for what ever increase in rear end turbulence can't possibly out weight the drag and lift effect caused by entire rear bumper especially the lower valance plus the vertical bits of metal I have disposed of. They all act as a wind brake because on the Polo there are big gaps that air travels either side of the wheel well only to get caught up at the end. Cars that have a flatter underside that fills the gaps between the beam and the bumper won't have this issue.
    Here is a sub 1 minute Civic at Tsukuba which has a well designed fiffuser that looks to be at the optimum 7-8* but because it also has provision for excess air to evacuate out of the bumper.
    So until I win lotto and can afford a fluid dynamisit like Andrew Brilliant and a wind tunnel this crude yet very common hatchback mod will do the trick
    No worries mate I wasn't really clear in what I was trying to say I guess, what I was saying is that the aerodynamic profile of the car is consistent, by no means is it efficient whatsoever the drag-inducing vortices are of a consistent pattern (thank you Melbourne weather an the 9n polo on the freeway this morning!) so by adding a volume of high-pressure air into the consistent wake of the car will change the balance, that's what I was trying to say...
    If you can extend the sills of the car downward as well as the front bumper, this will help quite a bit in keeping low pressure air under the car but you have to try and get a flat, level floor. Not like the factory underpanels which duck down under the subframe. It doesn't need to run the full length of the car and cover the whole lot in, just so long as its smooth and flat...
  7. #1037
    Feb 2007
    Brisvegas
    Turbo Trailer #2 Official 2013 Dreamworks Movie [HD] - YouTube
    Haha I'm off to have me a Nitrous bath
    Quote Originally Posted by Bullet Fast View Post
    Haha nothing good in life is easy!
    Quote Originally Posted by gavs View Post
    Ok sweet, do you know by any chance how far off the ground the front splitter and side skirts generally should be? I'm restricted a little by a 80mm class restriction and I'm already pretty low. I must say you've got me thinking about the diffuser again.
  8. #1038
    Jun 2008
    Ringwood, Victoria
    Little Red Devil
    Lower is obviously better, 80mm is pretty high but if you were to raise the suspension a bit and tweak your roll stiffness to counter the high COG (maybe also do some fun things with ballast...) you could make your bodywork lower to allow better under-car airflow.
    Just remember that a diffuser in whatever shape or form you go with, doesn't need to be the full width of the car, obviously wider is better but I you take your current exhaust point and work with that as your outer extremity off the centerline, you can still tailor a fairly simple undertray to work with it but like I said, skirts are needed to keep the under-car airflow nice and clean splitters also don't need to be the massive things you see on sport sedans and touring cars etc either, it just has to break the airflow.
  9. #1039
    Feb 2007
    Brisvegas
    Thanks mate, I'll do some measuring and take some shots to see what's possible. I really need some decent coilovers with stiffer springs I think, so I can raise the car a bit and not add any body roll. The FK's are as low as they will go without badly scrubbing out the inner tyre on the liners, and mated with both front and rear anti-roll bars on their hardest settings it's only enough to keep stability where I like it.
    Plus I'm a bit worried about aftermarket skirts for this Polo. The way that the chassis rolls under the car there is no way of telling just how much they will drop as a portion of them will stay above the lowest point of the sill. Plus there are no suppliers in OZ so would be luck of the draw from an OS supplier. Yet another challenge
  10. #1040
    Oct 2010
    Melbourne, VIC
    Modelling is easy if you assume laminar flow and no separation of the boundary layer and not too hard if you assume a constant position (or section for a 3D model) where the laminar boundary layer separation (and thus the beginning of the wake) occurs.
    In the real world, where you get varying separation and turbulent flow, ACCURATE modelling is almost impossible due to the effects if seemingly small disruptions in the body shape like windscreen wiper nozzles and the wipers and arms. The turbulence from these disruptions ALWAYS lead to early separation of the boundary layer, which is extremely difficult to model as the turbulence will start and increase as speed increases in unpredictable ways which then makes the drag coefficient change (usually for the worse). If you know EXACTLY what you are doing, then the situation can be improved by the addition of upstream vortex generators to create a turbulent boundary layer which can stay attached longer than a disrupted laminar one.
    Then we need to consider large disruptions to the flow like wheel wells, the wheels themselves, side mirrors...
    They still use wind tunnels for aircraft design, F1 etc for good reasons.
    I still don't see a diffuser being effective on a Polo without removal of the wheel well. There is just not enough length available behind it for it to work. A good flat bottom tray and as much skirting as clearance allows to just to decrease drag is about the best you can do (and hence also increase the effectiveness of the front spoiler above the splitter). Conceivably, you could get some downforce by adding ducts from the base plate to the holes in the bumper as the low pressure in the wake could draw air from under the car - you'd have to test. Of course you could easily totally unbalance the car with masses of front downforce and not much at the rear.
    That Civic pictured earlier has a massive rear wing mounted as far back as possible, again, for good reasons.
    Resident grumpy old fart
