Page 102 of 111 FirstFirst ... 25292100101102103104 ... LastLast
Results 1,011 to 1,020 of 1101
Thread: Little Red Devil
  1. #1011
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by VWindahouse View Post
    Yeah heaps apparently Clay. A hatchback coupled with a rear torsion beam suspension set up is no friend to efficient aerodynamics.
    I don't see the rear torsion beam as being an issue - in fact I think it is better than anything else for clearing the space at the rear. Rear wishbones or a multi-link rear end would place more components in the air path.
    Yes I don't really think a perfectly functional rear diffuser is an option with this car.
    I think you could make it work if you were to remove the spare wheel well but then you would need to reroute the exhaust to the side directly (use a big resonator instead of a rear muffler?) to make it full width.
    Resident grumpy old fart
  2. #1012
    Feb 2007
    Brisvegas
    Quote Originally Posted by kaanage View Post
    Greg, sorry I meant that you can't attach a flat diffuser to any part of the beam or over it because of the suspension movement.
    I would love to delete the well, but in both categories I'm looking at competing in you can't. Plus I might look at adding a fuel cell for the E85 in it eventually.
  3. #1013
    Oct 2010
    Melbourne, VIC
    I don't see the air path being long enough with the spare well in the way to prevent early separation in a rear diffuser - there is just just too little overhang in the bodywork, even if you were to try to re-energise the airflow with an exhaust slot at the top.
  4. #1014
    Jun 2009
    Are you able to raise the spare wheel well so that it sits higher up in the bodywork (essentially having the top of the spare sit up into the boot floor area)?
  5. #1015
    Feb 2007
    Brisvegas
    You're right, that's why most functional diffusers stick out a fair way past the rear bodywork. But again not allowed in one of the two categories. Plus in both I can only move the exhaust 100mm from the original placement. All leading me to the decision to just reduce drag at the rear.
    And I must say even at highway on ramp speeds I can feel a positive difference.
  6. #1016
    Feb 2007
    Brisvegas
    Quote Originally Posted by team_v View Post
    Ummm I'll check the ruling but I don't think any modification of the chassis is allowed.
  7. #1017
    Oct 2010
    Melbourne, VIC
    The other issue with the minimal rear overhang is the lack of cantilever effect which gives any downforce generated by a diffuser greater effect (though that then needs to be balanced at the front with a splitter).
    Could you run the exhaust outlets high up through the valance? Say in the middle? That would further help reduce the wake drag over the openings you have made already (which is where I think you are getting the real drag reduction benefit).
  8. #1018
    Feb 2007
    Brisvegas
    Sorry do you mean cut another hole in the remaining top bit of the bumper for the outlet?
  9. #1019
    Oct 2010
    Melbourne, VIC
    Exactly - then the hot (expanding) exhaust gasses will increase the pressure as close to the rear stagnation point as possible which should reduce the wake drag by the maximum amount (thought experiment going on here ).
  10. #1020
    Feb 2007
    Brisvegas
    Not a bad idea actually. Two things I'll have to measure up. The first is the no greater than 100mm from the original outlet. And the second and the one most likely to kill the notion is having to cut so far up into the chassis and R-bar
    So if I can't my back up was always calculated. The plan was to shorten the outlet (now single) and raise the muffler up in the tunnel to be higher than the bottom of the wheel well and torsion bar. That's why I went with a 6" round muffler away from the Milltech which is 8.5" wide 5" tall oval with long 10" dual outlets. So no part of the exhaust will be in the path of airflow at the rear.
    Anyhoo I measure up and get back to you
