Page 1 of 33 12311 ... LastLast
Results 1 to 10 of 1101
Thread: Little Red Devil
    Feb 2007
    Brisvegas
    Little Red Devil
    Hey there guys, I have been wanting to introduce you to my little red pride and joy for ages and I finally found some time to post up. I have had my GTI for almost three years now and I can't get enough of it and the VAG culture I have found on the forum! Spending so much time on this forum and on the net researching has been a massive thorn in side of my relationship, but I have promised my girlfriend that my modding journey is almost at an end 'cough, cough'.
    Just a couple shoutouts first all to Shane (shaneth) for helping me out with heaps of stuff on the Polo (group buys, parts, golden advise & for getting me in contact with Jimmy & Gavin). Gavin from Custom Code for a great product and for flying all round the country side to feed my need for speed. Greg from gslrallysport for the brake pads and rotors, great service and great prices. And last but certainly not least Jimmy Mac from Alba European. My little beast has probably spent 1/3 of its life at Jimmys getting the royal treatment. Mate your attention to detail, care, customer & quality of service are second to none!
    A few pics
    Latest list of mods 09/09/13;
    Custom Code Stage III tune
    3” cold air feed ducting
    Modshack VTDA with custom cold air 3” ducting inlet with K&N pod filter
    Custom alloy 3" MAF housing
    Custom 3" turbo inlet pipe
    Billet Turbo Ko3s Hybrid turbo with ceramic ball bearing conversion with Forge adjustable spring turbo actuator - yellow spring
    Forge Motorsport 007P closed loop diverter valve with yellow spring rated 15-23psi
    SEAT Sport intercooler - dual pass core
    Custom pipe work - 2" hotside, 2.5" coldside to TB
    ATP turbo hiflow exhaust manifold HPC coated
    Custom stainless steel 3” dump pipe with 4" expansion chamber & Magnaflow 100 CEL catalytic converter
    Custom 3" stainless steel catback exhaust with Magnaflow resonator & 6" round muffler with 42DD 4" outlet
    Phenolic intake manifold gasket
    ECS lightweight crank pulley
    42 Draft Design Ultimate catch can with Morosso exhaust valve and PCV delete
    SAI Pump, N249 & N112 delete
    Wahler 71c thermostat
    Genesis II 500cc injectors
    Bosch 3 bar FPR
    APR high performance in tank fuel pump
    Verdict Motorsport O2J aluminium shift bracket bushings
    42 Draft Design aluminium shift cable bushings
    Deka lightweight ETX14 battery 12lbs 5.4kg
    Braille aluminum battery mount
    NKG BKR7EKT spark plugs
    Superpro sports dog bone bush
    Vibra-Technics Gearbox mount
    Vibra-Technics Engine mount
    Audi A3 custom drive shaft
    Sachs 228mm duty clutch plate
    Sachs clutch pressure plate
    ECS 14lbs light weight flywheel
    Wiechers steel front strut brace
    Ultra Racing front lower control arm brace
    Ultra Racing rear lower brace
    Ultra Racing middle lower brace
    Whiteline adjustable front sway bar 22mm set on hard
    Whiteline adjustable rear sway bar 20mm set on hard
    Whiteline rear shim kit +3mm toe in reduction
    FK AK coilovers
    K-MAC front camber & castor adjustable top mounts
    Superpro anti-lift poly rear control arm bushes
    Brembo 4 pot front brake calipers
    Remsa Master HPT front brake pads
    DBA 4000 312mm front slotted rotors
    Audi TT rear brake calipers
    Lucas/TRW rear brake pads
    RDA 256x20mm ventilated rear slotted rotors
    HEL braided brake lines
    Enkei RPF1 17x8, 35ET, 15.5 lbs 7kg
    Federal EVO 595 215/40R17
    MK5 Golf alloy steering wheel inserts
    SWG air vent pod
    Prosport Evo electronic boost gauge
    Prosport Evo electronic EGT gauge
    Prosport Evo electronic air fuel gauge
    ANS-420 head unit
    Ford Focus RS bonnet vents
    APR Performance GTC-200 48" SCCA Spec. carbon fiber rear wing
    Rear bumper valance delete with JMF alloy bumper diffusers
    Sharan antenna
    Colour coded rear valance
    Badgless upper honeycomb grille
    Rear wiper delete
    Fog lamp delete
    Side skirt delete
    Stripped out rear end
    Total weight saving measures so far over 60kgs
    OILS, LUBRICANTS & Fuel
    Redline MTL gearbox oil
    Penrite SAE 5W 30 engine oil
    Penrite Racing Dot 4 brake fluid
    BP Ultimate 98ron
    Mar 2009
    Sydney {GO BLUES}
    awesome car buddy
    where'd you get the badgeless grill?
    APR V2 | APR Downpipe + custom catback | APR solid mount | FMIC | SEAT intake | BMC filter | FORGE 007DV | KW v1 | WHITELINE RSB
    139Kw | 271.8Nm atw - At a new home
    Feb 2007
    Brisvegas
    Quote Originally Posted by bfeboi View Post
    awesome car buddy
    Thanks mate! I got it off Ebay from a German seller. I think they are all out now from memory, sorry.
    Feb 2007
    Brisvegas
    Here are some of the gauge senders and Jimmys stealth like install under the hood, the two pics on the left show the fuel pressure sender. The other two are the oil pressure and boost senders.
    Dec 2006
    Mate looking sweet, now get it out to the drags
    Quote Originally Posted by seangti View Post
    The price of the car rarely indicates driver ability/lap time.
    Nov 2008
    Canberra
    Great stuff. Any reason for using Redline MT90 rather than MTL (what's usually recommended, I think) in the gearbox?
    Feb 2007
    Brisvegas
    Quote Originally Posted by jasn78 View Post
    Cheers mate, and I will just as soon as Jimmy can fit me in to get this stuff put in;
    K04-001 Hybrid turbo
    ATP turbo manifold
    And on their way from the US as we speak are;
    Bosch 315cc fuel injectors
    ECS adjustable fuel pressure regulator 25-80+ PSI
    Audi TT 225hp 3” MAF housing
    APR high performance fuel pump
    Then it's Custom Code Phase III time
    Feb 2007
    Brisvegas
    Dec 2006
    awesome car buddy
    btw best place now to get them is fkautomotive (sorry for the hijack) anthony
    Feb 2007
    Brisvegas
    No probs Jason, share the love!
