Either that or the battery
My Polo has a couple of issues recently. The latest is happening upon starting it after it has been sitting for a while.
The headlights and dash lights dim and brighten and then repeat for a while until the idle seems to settle. It also has an effect on the A/C fan speed. has anyone else had this or a similar issue and what is it? Could it be that the alternator is on its way out?
Thanks for the help and advice.
Some say...
I'd be cleaning all your battery terminals & earth connections & the connections to the big fuses / relays near the battery. Check the resistance of the cables. There are known issues if you search this sub-forum.
Thanks for the advice guys. I replaced the battery less than 2 years ago. If I clean it should I just use a cloth or are there particular methods and tools to use?
Some say...
You can use Baking soda dissolved in water or buy a terminal cleaner from Supercrap for $5 or so
The terminal cleaner is a double ended wire brush that has internal and external brushes that fit over the terminal and inside the clamps
they should be shiny. wire brush & fine wet/dry sandpaper is often helpful. terminal cleaner is good but doesn't get heavy corrosion off.
2yr old battery could still be the issue
Had a look and the terminals look pretty clean.
Some say...
clean and tighten the earths then
+1 for a battery. Even though its only a couple of years old it could still be playing up, especially if there are other electrical issues like the battery being drained constantly or the alternator not charging it properly.
I think it would be worth getting the battery tested and check that the alternator is putting out enough volts. Start with that ( as you can generally get them tested for free) and then work back from there.
