Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Lights dim and then brighten on start up.
    Dead cell? Got a multimeter?
    Cheap, Fast, Reliable. Choose two.
    Erskineville, NSW
    Quote Originally Posted by Stuwey View Post
    Quote Originally Posted by AALocksmiths View Post
    +1 for a battery. Even though its only a couple of years old it could still be playing up, especially if there are other electrical issues like the battery being drained constantly or the alternator not charging it properly.
    I think it would be worth getting the battery tested and check that the alternator is putting out enough volts. Start with that ( as you can generally get them tested for free) and then work back from there.
    Both these +++
    There's no point just doing a visual. You need to get out the multimeter & check the resistance or volt drop between 2 points as the corrosion can be within a cable (esp an earth or main power feed cable). Also clean the connector to the electric power steer
