Results 1 to 5 of 5
Thread: Legal height and Rear Sway Bar
    Jan 2009
    Hi all
    I was wondering what the forum thinks about legal height and RSB. I have a RSB and it is definitely the lowest point in terms of ground clearance.
    In Queensland I believe, the rule is it must be higher than a 100mm at the lowest point.
    I would like to install 25mm lower springs (I was thinking H&R) - will it still be legal?
    Feb 2008
    The way I see it...
    As the RSB is attached to an unsprung part of the vehicle, the RSB height will remain constant no matter how much you lower its springs(unless you add different wheels with increased/decreased diameter).
    So, what I am saying is, the body height will drop along with anything attached to the sprung part of the body (ie, exhaust), but the rear axle beam along with the RSB will remain the same height above the ground.
    Can anyone confirm/deny this...??
    Alfred Cove, WA
    Agree'd. Height of body will change, not un-sprung pieces.
    Quote Originally Posted by Kai View Post
    And then dont forget the most important mod for gays.
    Blow off valve - 300
    Quote Originally Posted by Ben_GTI View Post
    Seconded.
    Aug 2007
    Clear way to describe which is totally right mate.
    Jmac
    Alba European
