Results 1 to 2 of 2
Thread: Leaking drive shaft flange seals
    Oct 2009
    new south wales
    Hey Guys,
    I posted a thread some time ago, and this message is specifically relating to the leaking drive shaft flange seals. I finally had the car in for this to be sorted, and want to know if the dealer has actually replaced the seals. I'm a bit sceptical, because when home I jacked up the car to check their work, and it just looked the same, oily residue etc.
    Jmac gave me some part no's for the flange seals etc, and I assumed they were some sort of metal cap with rubber edges. When I picked car up, I asked what was replaced, and the service guy said they replaced a felt washer on either side, found no traces of oil inside, and that the oil present underneath the car was assembly fluid. I also asked if I could see what was replaced, but it was missing.
    Have they replaced/repaired the flange seals, or are they having a laugh?
    Furthermore, I cleaned up the area and checked again today, and yes oil has returned...
    Oct 2009
    Templestowe, VIC
    Not sure if it's the same thing, but I went back to the dealer with my week old Polo when it appeared to have an oil leak, and the inner cv areas were covered in an oily residue. Turned out to be the protective wax that the underside of these cars are coated in, had just melted in the heat. Looked very much like an oil leak also.
