Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: LCA bushes, who's using what
    Nov 2012
    WA
    So... I'm up for lca bush replacement. They've been done once before, the previous owner replaced them but replaced them with stock items
    Who is running what
    Seat equivalents
    Superpro, couple of options i.e., standard, anti lift, high performance
    Whiteline appear to do them as well? Two types a yellow and black presumably different hardness?
    Whiteline W0605 Control arm - lower inner rear bushing
    Whiteline W53196 Control arm - lower inner rear bushing
    Any comments on hardness, ease of install (anything DIY would be good)
    08 9n3 Polo GTI
    Mods: heaps
    Jan 2009
    blankedy
    Rears?
    Seat (many of us are). A few urn the superpro for the angle, I try to avoid adding more nolathane and similar as my toy is rigid enough without adding more vibrations.
    Jan 2009
    I have the Seat ones in the silver car after having the orginals replaced under warranty after 20,000. I think the Seat ones are a solid rubber, certainly much more robust than standard. I don't recall any increased NVH after them going in.
    RE the install, I believe you'd need a press to get them in and perhaps the current ones out.
    Daily: 2010 VW Jetta Highline
    nsw
    For the rear LCA bushes, decide if you want to run eccentric/offset bushes to get the anti-dive or caster increase benenfits. If you definitely want that, then you are locked into using steel cased bushes that need the VW tool at minimum to get them in. If geometry change at the LCA doesn't matter to you (while there are still steel and plastic cased centred bushes out there) then you could go for the whitelines that are not, and merely a tap in with a mallet. While cutting/pressing the old ones out took a bit of time, most of the effort was eaten up getting my steel cased LCA's in even with the VW tool - you can save that headache with the whitelines I'd reckon.
    If you want to do the front LCA bushes at the same time you will definitely need a press of somesort to get them out. I got them to budge on a lathe and then hammered them out and then the superpro's were a hand push fit to replace.
    I'm on the northern beaches if you want to have a squiz at mine before you go ahead.
    SuperPro, offset here.
    Cheap, Fast, Reliable. Choose two.
    Nov 2008
    Seat ones ... work fine
    Oct 2010
    Melbourne, VIC
    Has anyone tried both the SEAT and the offset SuperPro's?
    I'm very happy with the SEAT ones I got from Jimmy but I do wonder if I'm missing something
    Resident grumpy old fart
    Quote Originally Posted by rgvlee View Post
    Who is running what
    Seat equivalents
    I installed Polybush LCA front and rears from Bushes > Suspension > Polo 9N 02-09 > VW Polo > VW Specialists > PSI Tuning - VW Specialists
    Very happy with them. Borrowed the VW Tool from Gav to do them. I also made up a tool using endless threaded rod to do the LCA fronts. Cheers Al
    Quote Originally Posted by kaanage View Post
    Much better turn-in with the slight increase of castor. I'd live to know the definitive result o the 'anti-lift' part of the equation...?
    They're damn firm though.
    Superpro definitely prevents axle tramping. Have a look at my cheapy thread. Anthony has had both Seat Sport and Superpro in the Devil. I set the castor neutral on the devil and the Squib when I did them.
