Results 1 to 10 of 12
Thread: Locked keys in the car.
    Jul 2014
    Hi Guys,
    Opened the boot took some stuff out and left the keys in the boot when i closed it and the car has locked it self.
    is there anyway to "break" into it to get the car to unlock? iv rang around different road side assists and they cant guarantee that they will be able to get it. the guy from AAMI said something about shorting it out and it resets the electronics? would that mess with my ecu and tune?
    either way at this rate im looking at getting a quote for a window or hoping a lock smith can sort something out in the morning.
    2006 Polo GTI | APR Stage1 | PD160 | K&N Panel filter | Forge TIP | Forge DV | Forge IC Piping | Milltek TBE |
    | Forge Front/Rear Strut Braces | SEAT RCA Bushes|
    Dec 2008
    Sydney/Canberra
    Easiest would be to break a front door window. Not all that expensive.
    A locksmith may try and gently pry the top of the door frame out enough to run a length of wire into the car to hit the unlock button, or maybe snag the keys and pull them out through the gap.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jun 2011
    Sydney NSW
    Don't you still have the second key?
    Mar 2013
    Brisbane QLD
    Alianz roadside assist have to kit..they make up a profile for key barrel and there in. Saw it done on a new caddy drivers door..about 2 mins and it was open...
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Arrawarra
    I did that exact thing 18 months ago... NRMA tried for an hour with no success. I was able to jag the keys with a long wire through the 1" gap that i had left to let the hot air escape, that i usually do. Luckily back seats were folded flat!
    Good luck! I found out on a separate occasion (break & enter) that a front side window (though not for an 8 year old Polo) is over $400...
    Quote Originally Posted by rollehgoo View Post
    Hi Guys,
    Tune will not be affected.
    Never pop the boot on its own is the lesson here.
    If you are in Adelaide 100% I can get you into your car with no damage.
    I highly recommend not to get someone out who will butcher/ wedge your door as this can damage paint and door seals, also most of these cars deadlock so that won't get them in.
    If you let me know where you live I most likely know a locksmith in the area who can get you in. It wont be cheap but still better than smashing a window or getting someone out to "Have a go"
    Quote Originally Posted by AALocksmiths View Post
    Northside of Brisbane
    Rollehgoo. Check your pm.
    Jul 2014
    Thanks for the replies guys. i ended up getting a locksmith out to pick the lock on the drivers side and i got in. cost me $120 all up.
