It sounds obvious but; check everything. Go over the entire car and open/close/press/use everything. Find the issues of things that don't work.
I picked up my current 9N3 GTI from a toyota dealer in Port Macquarie a couple of months ago, its a 08 model they got on trade and came with 11,800Km on the clock for $15k.
The dealer put 3 months of warranty on it and told me if I had any issues to just take it to VW themselves or my preferred mechanic and have them bill them for anything that would be covered by a factory warranty.
I just noticed today that my rear wiper does not spray water when its activated so I intend on having it looked at which leads me to my question..
Is there anything else i should get them to check for while i'm at it, any niggling issues you wish you'd claimed while you had the chance?
I kinda feel like asking them to go over it with fine tooth comb.. why not right?
Heres a couple:
Have a look at the rear control arm bushes and your drop links. Also listen to your AC compressor and auxiliary air pump (can you hear a whining noise on start up?).
Edit: at those low k's the only one of those that might apply would be control arm bushes.. maybe
Keep a keen feel out for gear box crunches.
Fill up the water bottle for the wiper maybe.
The rear washer takes a few seconds to get water to the jet, so try and give that a go.
Thanks for the responses, few things to check for there cheers!
The rear washers is the issue that lead me to even think of making a claim, I removed the boot cover and the hose is connected but I don't remember it working from day one so it has to be a problem elsewhere along the line
on a brighter note I have the Apr tune booked for monday![]()
also, I've noticed that my power steering may be a little noisy.. Its most noticeable when I reverse out of my carport in the mornings and chuck a 2 point turn, I can hear the motors whirring from inside the cabin and I don't remember hearing that in the 07 model I had a few years back..
Scuse my paranoia but I just cant figure out why it only had such low k's on it when i picked it up and i've been looking for problems since..
I have a 2008 Gti with approx 72ks and the PS does whiring noises and has done since I got it. If that's the only issue I will be happy. Cheers Al.
